would this mean my rings are fried?
basically wat the title says:
back of the gasket [IMG]
[/IMG]
front of gasket.(exhaust manifold) [IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
i noticed its only hella bad on the two inside ones. any help would be great.
but ill prob be ignored like always.
[/IMG]front of gasket.(exhaust manifold) [IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]i noticed its only hella bad on the two inside ones. any help would be great.
thank u.. when i did my head gasket a few weeks ago thinking that was the prob my cylinder walls looked untouched and looked as if there was no oil slippin by them u know but then seein this got me thinkin can i still fix the motor or is it crap. how can i check the seals and guuides?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superfast666 »</TD></TR><TR><TD CLASS="quote">could be that or valve seals or valve guides</TD></TR></TABLE>
how many miles does the block have on it?
with that kind of millage, its definately a possibility that the rings are done. but if u wanna know for sure, the easiest way to find out is to do a dry and wet compression test. if the wet test shows higher compression, that tells you the rings arent sealing properly. if both the tests give you readings that are pretty close then you have head problems.
ok ive basically said srcew it and decided to pull the punk out and jus throw the zc in i jus wanted to know so i could fix it as a worse case scenerio back up motor ya dig lol but thanks and ill definetly do the compression test still
Sohc Turbo
Feb 16, 2006 08:44 AM
