anyone ever heard of this technique
Old Jun 2, 2008 | 02:46 PM
nauc's Avatar
Default anyone ever heard of this technique
i have a 99 Accord and the Maintenance Required light on my dash came on today. so i took it to a mechanic and the mechanic asked me if i got gas today. i said yes. then he asked me if my car has been driving fine and i said yes again. so he tells me to try this.. drive the car for a few days to see if the Maintenance light goes off. he said that some air may have gotten into the gas tank when i got gas and also told me to take the gas cap off, then put it back on, making sure it clicks several times.
anyone every heard of this
Old Jun 2, 2008 | 03:49 PM
FunnyVictor86's Avatar
Default Re: anyone ever heard of this technique (nauc)
all you have to do is reset it ...
1.Start with the car off.
2.Place the key in the ignition in the off position.
3.Press and hold the Select/Reset dial beneath the speedometer.
4.While continuing to hold the dial, start the car.
5.Continue to hold the dial for a few seconds until the light turns off
Old Jun 2, 2008 | 04:30 PM
02 accord's Avatar
Default Re: anyone ever heard of this technique (FunnyVictor86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FunnyVictor86 &raquo;</TD></TR><TR><TD CLASS="quote">all you have to do is reset it ...
4.While continuing to hold the dial, turn the ignition to on
5.Continue to hold the dial for a few seconds until the light turns off</TD></TR></TABLE>
There is no need to start the car.
Old Jun 2, 2008 | 04:33 PM
spinimbus's Avatar
^^^ Bingo. Pretty much the light comes on when it is about due for routine maintenance. Reminder to do oil change, inspect air filter, check brake pad wear, and whatever else you feel like tinkering with. Nice to have with a busy lifestyle!
khronicboy420
Dec 24, 2008 10:18 PM
Eran
24
Feb 28, 2007 07:04 PM
ludenutz
Jan 23, 2004 10:44 AM
weakGOODJunKieS.com
Mar 23, 2003 03:44 PM
weakGOODJunKieS.com
Mar 8, 2003 02:10 PM
