00 si tranny help
Old Jun 2, 2008 | 12:49 PM
b16_swap's Avatar
Default 00 si tranny help
i have a 00 civic si with b16a motor, i am bout to do a tranny swap cuz my tranny in their now gone bad making noises, wont go into gear n wut not, i have my old tranny, its the same exact tranny and i just need some "how to" do a tranny replacement guide, i'd really appreciate it.
Old Jun 2, 2008 | 03:57 PM
inspyral's Avatar
From your other thread:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">1) Get the front end of the car up on jackstands and take the two front wheels off.
2) Drain tranny fluid.
3) Pull both axles along with intermediate shaft. Most people like to do this by separating the knuckle from the LCA at the lower ball joint. My castle nuts were always a bitch to get off, so I've always just dropped the upper control arm to get axles out.
4) Disconnect and remove the starter. Disconnect VSS and back-up switch plugs. Unbolt clutch slave cylinder and move it out of the way, or undo the clutch cable and move it out of the way if it's a cable tranny.
5) Double check that there are no other misc items still attached to the tranny.
6) Unbolt shift linkage, punch out bitch pin. You can leave the shifter end attached to the chassis and let it hang, or unbolt it and drop the entire linkage/shifter out of the way.
7) Get a 2x4 or a piece of wood of some sort and place it on the lifting pad of your jack and support the block with the jack. Make sure the piece of wood is between your oil pan and the jack.
8) Start loosening the passenger side torque mount, upper tranny mount, and rear tranny bracket. You can also start loosening the boltsholding the bell housing of the tranny to the block, but leave them in place.
9) Once all the mounts are out, start removing the bolts holding the tranny to the block, and position another jack under the tranny.
10) Once all the bolts are out, have a friend stabilize the tranny as you use a gentle rocking motion to split it from the block. Once you have a bit of a gap between the tranny and block, you can use a pry bar to gently persuade it apart. Once it's apart, use the jack to support its weight and lower it out from under the car. If you have really strong friends, it's also possible to do this lying on your back under the tranny, but it's kinda heavy and not well-balanced, so use your best judgment.
11) Prep new tranny for install. Grease up the clutch fork pivot point. Grease up your new throwout bearing and put it on the input shaft. Install clutch fork and grease the slave cylinder pivot point.
12) Install new clutch/flywheel/pilot bearing if applicable.
13) Place new tranny on jack and raise it into place(or have a strong friend bench press it into place), while you or a friend checks the alignment and mates it to the block. This can be a tricky step, so it definitely helps to have a friend or two assisting you.
14) Reassemble everything in reverse order. Torque all fasteners to spec. Reconnect all accessories and plugs. Fill with ~3qt of Honda MTF, 10w30 motor oil, or your preferred MTF.
15) Have fun with your new tranny.
This is all off the top of my head, so please excuse me if I skipped anything important. Feel free to add to it or correct any mistakes I may have overlooked.</TD></TR></TABLE>
Old Jun 2, 2008 | 08:31 PM
b16_swap's Avatar
Default Re: (inspyral)
thanks for the help man, if u can supply any kinda of pics of the bellhousing that owuld help and thank s again
Old Jun 3, 2008 | 04:59 PM
Mike_C's Avatar
the bellhousing is the transmission. it's big, silver, and not the block.
Old Jun 3, 2008 | 07:47 PM
b16_swap's Avatar
Default Re: (Mike_C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike_C &raquo;</TD></TR><TR><TD CLASS="quote">the bellhousing is the transmission. it's big, silver, and not the block.</TD></TR></TABLE>
Gotcha man
Old Jun 7, 2008 | 06:46 AM
b16_swap's Avatar
Default Re: (b16_swap)
where is the vss cable located and where is the clutch slave cylinder located??????
Old Jun 7, 2008 | 06:48 AM
turboedsupe's Avatar
Dude if you dont know where either of those are then maybe you shoudl have someone swap out the tranny for you
Old Jun 7, 2008 | 07:00 AM
b16_swap's Avatar
Default Re: (turboedsupe)
prolly should, and i would if i had the bread
b16_swap
Jun 8, 2008 02:43 PM
2wheelhunter
Dec 1, 2006 09:04 PM
90LSpimpin
Dec 15, 2004 03:19 PM
dj_seloe
17
Oct 26, 2003 10:38 AM
