98-2002 Accord Chassis code engine code question
Old Jun 2, 2008 | 08:35 AM
tegmaniac's Avatar
Default 98-2002 Accord Chassis code engine code question
Does anyone have an Accord with a CG6 chassis and an F23A1 engine from the factory? If so, what model year is it?
I know it comes with a F23A4 engine for sure, but the Honda online service info is saying that for certain model years you can get both engines for this chassis. I only want to verify, because sometimes service info is not always 100% correct.
BTW. If the F23A1 can be found on the CG6 chassis then, what is the difference between the CG5 and CG6?
Thanks for the help.
Old Jun 3, 2008 | 06:23 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: 98-2002 Accord Chassis code engine code question (tegmaniac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegmaniac &raquo;</TD></TR><TR><TD CLASS="quote">... what is the difference between the CG5 and CG6? </TD></TR></TABLE>
I don't know for sure but based on the chassis codes for the 5th gen I would take a guess that one is a Sedan and the other is a Coupe.
Old Jun 3, 2008 | 02:39 PM
tegmaniac's Avatar
Default Re: 98-2002 Accord Chassis code engine code question (TouringAccord)
No they are both sedans, but thanks for the response.
Old Jun 4, 2008 | 08:51 AM
H-T Order of Merit
what service manual are you looking at? Are you looking at the PDF downloadable ones? If so, they are probably listing chassis codes from other countries like the CD5 is a 94-97 Sedan in the US while the CD6 is a Sedan in Japan.
Old Jun 4, 2008 | 09:13 AM
H23 Power's Avatar
yeah, looks like CG6 were made in Japan and CG5 america.
Old Jun 5, 2008 | 05:12 AM
tegmaniac's Avatar
Default Re: 98-2002 Accord Chassis code engine code question (H23 Power)
I'm looking at https://techinfo.honda.com/rjanisis/logon.asp. It is the same site the dealers use.
Looking at 1999 and 2000.
CF8:
ACCORD/F23A5
CG3:
ACCORD COUPE/F23A1, F23A4
CG5:
ACCORD/F23A1
CG6:
ACCORD/F23A1, F23A4
For 1998, 2001 and 2002 the website is saying CG6 only came with the F23A4
Old Jul 25, 2010 | 12:36 AM
Pillza's Avatar
What does the number (3003108) behind the chasis code mean? (e.g. CM2-3003108) Does it have any special meaning?
Old Jul 25, 2010 | 09:08 AM
20-EM2-05's Avatar
Just the rest of your vin number.
vegaskurt
Mar 31, 2005 12:43 PM
91 HONDAsaurus rex
Sep 28, 2004 03:40 PM
Drum_Guru
Aug 10, 2003 12:15 PM
AzntaggeR
Mar 15, 2003 11:58 PM
phatridinDus10
Jan 21, 2002 03:43 AM
