Starting issue, new issue..
Old Jun 2, 2008 | 07:52 AM
civic402lx's Avatar
Default Starting issue, new issue..
this is the 3rd time i've notice this problem on my gsr swap..yesterday morning i drove the car for 1 hr, it started fine..came home, parked the car from 9-3pm..it's about 86 degree F outside, all window up..
went out to start the car and it starts for 2-3secs then shut off..tried again and it just won't start..it'll crank like it want to turn over and but it won't..did this like 4-5x and it won't start..
rolled all the window down...fix my cluster bulb problem..about 10mins later, start her up and she start just fine..like nothing happen..i've notice that this only happen when it's really hot outside...well the last time it was at night..
could the cabin heat just make the ecu too warm to start?? i'm running a jdm p72 ecu virgin..
mods:
i/h/hf cat/ ex/ctr cams/skunk2 IM/hondata im gasket/denso iridium plugs/ngk plug wires..
full tank of gas, premium..battery is good, new alternator, new cap and rotor, plugs and wires..all these were changed a couple of months ago..about the same time..
i checked battery connection and it's fine..on really tight..ground points are good and clear..fuel pump still prime the system whenever i put the key on the "on" position.
checked all the fuses, all are good..don't know where the fuel relay is at so can't check that..filter are clean, just cleaned it 2wks ago..
don't know wat's going on with it..just started a month ago..the swap been in there for over 1yr w/out problem..i also have a CEL but that's because i have the skunk2 intake mani, so it's for the butterfly thingy..
any opinion??
thanks
Old Jun 2, 2008 | 07:55 AM
xJ.SLOTHx's Avatar
Default Re: Starting issue, new issue.. (civic402lx)
check your main relay. its under the dash. it will fail at times when the car is hot interior wise. seen it happen a lot
Old Jun 2, 2008 | 08:02 AM
civic402lx's Avatar
Default Re: Starting issue, new issue.. (xJ.SLOTHx)
wt will it say on the relay? and where under the dash do i look?? sorry don't know about this fuse and relay stuff..
if it is the relay, how much do u think it cost to have it replace?? can i get it at any local part store?? i want to get this fix by jun. 11 because i'm leaving town and i need this to work..
thanks
Old Jun 2, 2008 | 08:15 AM
civic402lx's Avatar
ok..i found it..it labeled on there..i took it out, just want to make sure if this is the one u're thinking about..but here's a picture of it..i have no clue how to check to make sure it's good or not..
i shook it and can't hear anything loose inside..so i don;t know..
Old Jun 2, 2008 | 08:40 AM
SamSpade's Avatar
Default Re: (civic402lx)
That is the correct relay. It's also the source of your problem. If you pop off the brown cover, you'll see the circuit board. On this borad is about two dozen solder points. If you look closely, some of the points will have what appears to be small halos around them. These points need to be resoldered. Over time, the solder points have expanded and contracted so many times with heat and cold that the points begin to crack. In the extreme heat (or even humidity) the board expands making you experience the situation you desribed. This is the fix for your problem.
Everytime i have a new customer with a honda/acura, i remove this part and solder all the points. Unfortunately it's a known problem with our cars. Cheers.
Old Jun 2, 2008 | 09:07 AM
civic402lx's Avatar
Default Re: (SamSpade)
sweet thanks..well i just purchase a new one off ebay for 40shipped..just in case i f*ed this one up..gotta have a spare..
thanks for the confirmation..now i feel better knowing it's not something major that went wrong..
i took the cap off and this is wat i'm looking at..it look ok to me..i don't see anything out of place..is it me?? probably..
can u point out the problem on this?
thanks
Modified by civic402lx at 10:15 AM 6/2/2008
Old Jun 2, 2008 | 09:21 AM
SamSpade's Avatar
I need to have it in my hand when i look at it. The halos are very small. Anyway, all you have to do is re-solder each of those points and your problem will be solved. If you don't trust yourself to solder the points, bring the part to a stereo installation shop and have them do it. It shouldn't take more then ten minutes. Cheers.
Old Jun 2, 2008 | 09:24 AM
civic402lx's Avatar
ok..i understand...
thanks again..i'll try it later today..
Old Jun 2, 2008 | 06:21 PM
civic402lx's Avatar
Well, i installed it after having my friend desolder and solder everything back with new solder..it turn on right away..only time will tell..tomorrow will be hot also, so..we'll see if the problem go away...i'll be back in a couple of days with update..
thank you all..
Old Jun 7, 2008 | 07:58 AM
BigFitz's Avatar
I've had a similar problem with a 1992 Civic. What year and model is your car?
Old Jun 7, 2008 | 02:46 PM
civic402lx's Avatar
Default Re: (BigFitz)
95 civic lx 4drs...it work great after new solders..i bought a brand new one as a spare to keep it in the car just in case it happen again..but judging from wat happen the past few days..it's working great again, even when it's really hot out or inside the car..my car sat in the sun for 12hrs and it started up perfectly after the solder job..
xXViperXx
13
Jan 14, 2015 09:31 PM
F20B_accord
Apr 23, 2012 12:06 PM
chinese buffet
Jul 16, 2006 05:09 AM
akferdinand
Nov 8, 2004 05:48 PM
Honda Sport
Jun 4, 2003 05:27 PM
