Oil Pan Question****
what zc engine do you have?
Dohc or Sohc?
if its dohc then it will be an 88-89 Integra...
sohc i believe would be the same thing as the d16a6 (civic/crx si 88-91)
Dohc or Sohc?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin »</TD></TR><TR><TD CLASS="quote">im pretty sure all d series oil pans are the same, not so sure about the dohc though. </TD></TR></TABLE>
yes they are all the same including the dohc zc any one should fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 »</TD></TR><TR><TD CLASS="quote">All 88-91 oil pans are the same (just different size drain plugs), </TD></TR></TABLE>
What do you mean different size drain plug. There all 17mm
And if this is going on a daily driver I would try to stay with a oem pan because aftermarket pans are normally aluminum which can be easily cracked or even bust if you bottom out some how.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 »</TD></TR><TR><TD CLASS="quote">My 89 DX pan (not sure if its OEM) has a 15mm plug for some reason??? </TD></TR></TABLE>
You might want to check into that. That might be off of a ford or chevy. The standard honda plug is 14mm with the 17mm head. PN is 90009-PH1-000
Thats what I thought but I went to do a oil change and got a filter and plug from Honda and it didn't fit so I went to auto zone and they had 3 size in there system (14,15,16mm) so I got all 3 and the 15 fit??? Doesn't leak or anything, had it in for 3,000 miles and I'm about to do another oil change on next week. But so far no leaks, none.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rival12 »</TD></TR><TR><TD CLASS="quote">It's a dohc ZC, with a GReddy header...
88-89 Integra seems to be what i come up with.</TD></TR></TABLE>if you use the Integra pan, you also need to use the Integra oil pick-up - the D16A6 Si pan is a better choice - it fits the ZC pickup - the ZC pan is slightly deeper than the D16A6 and holds 1/2 quart more oil - the Integra pan is deeper and may not clear the header
Modified by jlicrx at 12:19 PM 6/2/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 »</TD></TR><TR><TD CLASS="quote">Thats what I thought but I went to do a oil change and got a filter and plug from Honda and it didn't fit so I went to auto zone and they had 3 size in there system (14,15,16mm) so I got all 3 and the 15 fit??? Doesn't leak or anything, had it in for 3,000 miles and I'm about to do another oil change on next week. But so far no leaks, none. </TD></TR></TABLE>
That is weird. What size was the old plug that you took out? Couldn't be a different oil pan. Could it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">if you use the Integra pan, you also need to use the Integra oil pick-up - the D16A6 Si pan is a better choice - it fits the ZC pickup - the ZC pan is slightly deeper than the D16A6 and holds 1/2 quart more oil - the Integra pan is deeper and may not clear the header
Modified by jlicrx at 12:19 PM 6/2/2008</TD></TR></TABLE>
Thanks, The CRX pan looks exactly like the pan i need. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 »</TD></TR><TR><TD CLASS="quote">And if this is going on a daily driver I would try to stay with a oem pan because aftermarket pans are normally aluminum which can be easily cracked or even bust if you bottom out some how.</TD></TR></TABLE>
what's bottom out?
what's bottom out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rival12 »</TD></TR><TR><TD CLASS="quote">I have a ZC engine, and the oil pan drain plug seems to be stripped. I'm wondering which oil pan will fit.</TD></TR></TABLE>
Do you mean that the head of the bolt is rounded off or the threads on the pan itself are stripped out?
From reading the response posts it sounds like the threads are stripped. I was just looking for clarification.
I think the pan is stripped....
The bolt turns, then gets loose, then tightens until the bolt is screwed all the way in, and then it won't lock in tight. It gets tight, then loosens, then tight and loosens...
And oil is leaking from it.
The bolt can screw in and out....just won't tighten all the way in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acmoc »</TD></TR><TR><TD CLASS="quote">what's bottom out? </TD></TR></TABLE>
Are you serious?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rival12 »</TD></TR><TR><TD CLASS="quote">I think the pan is stripped....
The bolt can screw in and out....just won't tighten all the way in.</TD></TR></TABLE>
What you need to do then unless you already tried. Buy a new plug and try it in the pan first before you buy another pan. GL with it.
Are you serious?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meandino »</TD></TR><TR><TD CLASS="quote">
Are you serious?
... Yea, I don't know what it is. Gosh you don't gotta hit me in the head with that hammer.
Is it something like your suspension gives, the rear
Are you serious?
... Yea, I don't know what it is. Gosh you don't gotta hit me in the head with that hammer.Is it something like your suspension gives, the rear
