dr-20 low offset question???
Old Jun 1, 2008 | 09:57 PM
jdmer4life's Avatar
Default dr-20 low offset question???
will these wheels fit my 98 integra gsr? the specs on these wheels are 15 x 7 an the offset is +10.. any input will be appreciated Thanx
http://dragwheels.com/product.asp?ID=110
Old Jun 2, 2008 | 05:03 AM
Loco-B's Avatar
Default Re: dr-20 low offset question??? (jdmer4life)
no they wont fit at all.
Old Jun 2, 2008 | 04:16 PM
jdmer4life's Avatar
Default Re: dr-20 low offset question??? (Kurumi)
really!? cuz I've seen zero offsets on integras and on a 8 in wheel. i though this one could work better cuz its a 7 in wheel...
Old Jun 2, 2008 | 04:21 PM
Loco-B's Avatar
you just answered your own question
personally might fit better than a 15x8 with a +0 e.t.
Old Jun 2, 2008 | 05:21 PM
xJ.SLOTHx's Avatar
unless you add mass amounts of camber and alot of fender rolling and pulling they will still stick out to much and look silly.
Old Oct 30, 2008 | 12:43 PM
thatDA's Avatar
Default Re: dr-20 low offset question??? (Loco-B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loco-B &raquo;</TD></TR><TR><TD CLASS="quote">no they wont fit at all. </TD></TR></TABLE>
Old Oct 30, 2008 | 06:13 PM
alphalanos's Avatar
Technically they arent the correct fitment. But you can make them fit. Depending how low you are you might need to roll fender.
7in = 177.8mm/2= 88.9mm-10 offset= 78.9mm from hub to lip. So assume +40 offset is about 10mm inside the fender. 78.9-40-10= 28.9. The wheels will stick out of your fender 1.1 inches. So youll need a some camber.
Old Oct 31, 2008 | 02:33 AM
dumada9's Avatar
Default Re: dr-20 low offset question??? (alphalanos)
its easily possible if your car is slammed. i have those rims. you might need to roll your fender a bit, but it shouldnt be too hard to fit
Old Oct 31, 2008 | 05:29 AM
luvtositdumpt's Avatar
From: somewhere in the d, mmm stake, mmm country fried stake
they will fit...dump the car and roll/pull the fenders...
7.5 on +15
Old Oct 31, 2008 | 06:13 AM
efvader's Avatar
Default Re: dr-20 low offset question??? (xJ.SLOTHx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xJ.SLOTHx &raquo;</TD></TR><TR><TD CLASS="quote">unless you add mass amounts of camber and alot of fender rolling and pulling they will still stick out to much and look silly. </TD></TR></TABLE>
Old Nov 2, 2008 | 03:56 PM
dumada9's Avatar
Default Re: dr-20 low offset question??? (efvader)
my da is rocking 10 offset and it only required rolling the fenders and i could still put 5mm spacers in front. but i think its easier to fit low offest on a da than a dc
Old Nov 2, 2008 | 06:41 PM
tai....'s Avatar
yeah they will fit..like others said just prolly need fender roll/pull depend on how low u are
Old Nov 3, 2008 | 04:04 AM
PHATJM's Avatar
^ as above they'd fit but it wont be "to easy".
just invest in a nice camber kit and pump your guards well enough, im sure you could make it work!
Old Nov 3, 2008 | 07:29 AM
jdmer4life's Avatar
thanks guys....
Old Nov 10, 2008 | 11:49 PM
dumada9's Avatar
Default Re: (jdmer4life)
you gotta have alot of camber if you're not gonna pull your fenders. i just rolled mine. but im rocking enough camber to make it sit flushed. actually my front i got go 5mm more
Old Nov 11, 2008 | 08:20 AM
also depends on tire size...if only they made 185 45 15/16...
Old Nov 11, 2008 | 12:55 PM
ejLday's Avatar
Class is in session haha
acap310
Mar 6, 2011 07:32 AM
EK99hatch
Honda Fit
Nov 14, 2008 05:23 PM
RuDsOnEr
Aug 9, 2008 12:14 PM
PNB
Honda S2000
Jul 4, 2006 02:09 PM
JAI-DM
May 2, 2005 04:11 PM
