Engine help
Old Jun 1, 2008 | 08:34 PM
Mac101989's Avatar
Default Engine help!!Asap!! =]
Ok i recently bought a 95 honda civic lx, and it was on 200k miles with its stock engine on it and everything else also, so i decided to swap the engine, and i went and bought a jdm engine, but im not sure what distributor, sparkplug wires and any other parts will i need to go ask for at the nearest auto parts store?heres the picture of the new engine i bought.
Modified by Mac101989 at 9:48 PM 6/1/2008
Old Jun 1, 2008 | 08:50 PM
deevin9's Avatar
Default Re: Engine help (Mac101989)
... you've started like 3 threads on this already?!?!
its a JDM SOHC non-vtec ZC. It bolts right into a 92-95 and you can run it off almost all of the same stuff (ecu, wire harness, manifolds, etc) if you need to change any parts, they are exactly the same as a D16A6 which is the motor from:
# 1988-1991 Honda Civic Si, CRX Si, Civic Wagon RT4WD
# 1990-1991 Honda Civic EX Sedan
# 1988-1995 Honda Civic Shuttle RT4WD (UK/Europe/Asia/AU/NZ)
# 1989-1996 Rover 216/416 GSi (UK/Europe)
Old Jun 2, 2008 | 01:08 PM
Mac101989's Avatar
Default Re: Engine help (deevin9)
yes i have, but thanks again man, cuz i was feeling less torque from the car aswell, and another problem was because now when i normally start up my car every morning it idles at around 2000 rpm, and 10 min later it stays at a low rpm of like 1500, but im not sure if this idle is normal.
Wolvy69
Audio / Security / Video
Mar 16, 2016 04:30 PM
panzer948
Jan 28, 2013 10:46 AM
bobjohnson
Apr 22, 2008 04:54 PM
darkirony
May 31, 2004 01:46 PM
Hotsauce026
May 2, 2003 03:38 PM
