B-series tranny help
Old Jun 1, 2008 | 05:33 PM
Hartattack's Avatar
Default B-series tranny help
Done a few searches but had a hard time finding any solid info on this:
I have a b18c1 swap in my eg hatch with the stock GSR tranny, the tranny is going out and I'm looking for a replacement. Since I am going to be doing a lot more freeway driving for school next semester I am looking at an Ls tranny. So here's my question, I know that the trans will bolt up just fine but could I use my upgraded act clutch and flywheel from the gsr trans on the Ls and have it work as well?
Sorry for the long post, but thanks for looking
Old Jun 1, 2008 | 06:13 PM
inspyral's Avatar
So you're going from a hydro GSR tranny to a hydro LS tranny? Yes, your clutch and flywheel should be fine.
Old Jun 2, 2008 | 06:15 PM
Agnom's Avatar
Default Re: B-series tranny help (Hartattack)
LS tranny has 4.2 final drive, good for mpg but bad for performance...
Old Jun 3, 2008 | 09:17 AM
gibsanez's Avatar
What's wrong with the transmission?
I'd sooner just to a 5th gear swap and keep the GSR ratio's.
Old Jun 3, 2008 | 11:01 AM
Hartattack's Avatar
Default Re: B-series tranny help (gibsanez)
Performance isn't that big of an issue right now since it is my daily driver. As for the tranny I have now it has a slight grind and 2nd gear pop-out. I thought about doing a 5th gear swap, but it sounds kinda pricy.
Old Jun 3, 2008 | 05:00 PM
Mike_C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hartattack &raquo;</TD></TR><TR><TD CLASS="quote">I thought about doing a 5th gear swap, but it sounds kinda pricy.</TD></TR></TABLE>
do it yourself... follow a helms and you won't have any problems. while you're in there, replace everything that is replaceable. you'll hate the ls trans mated to your gsr motor... it'd likely drop you out of vtec on upshifts.
igorka_91
May 4, 2010 08:14 PM
CRAZYEG9
Oct 20, 2004 05:07 AM
6shootahorsenamedtrigga
Aug 8, 2004 11:17 AM
Lightning Orders
Jan 3, 2004 08:12 AM
Chuji
Aug 3, 2002 05:01 PM
