Wont start, no spark
Old Jun 1, 2008 | 05:09 PM
1SlowSi's Avatar
Default Wont start, no spark
So the story is this... while swapping out plug wires the car decided not to start up again. I went back with the regular wires that worked just fine. I have fuel but no spark. The car ran fine, and all of a sudden just wouldnt start back up.
-Ive tried 2 sets of plugs all gapped at .040
-2 sets of wires
-Cap is brand new
-Rotor is fairly new and in good shape
-Firing order is correct
-Timing is fine was never touched
-Just tried a BRAND NEW igniter (control module), and still no spark
- Checked all fuses and all are good
I have no idea what else to do. The only real thing i have left to try is the actual coil. Do you think this was just quit out of nowhere? Any help is appreciated. thanks.
Old Jun 1, 2008 | 05:28 PM
PyroProblem's Avatar
Default Re: Wont start, no spark (1SlowSi)
From what Ive seen, coils go bad intermittently at first,then get progressively worse. Just like ignitors IMO.
Coils are easy and cheap enough to replace,Id say throw one in there just for the hell of it.
FYI-When I was a technician at a honda dealer, we suggested the customer replace the main relay,coil,and igniter. It was an expensive repair, but the only way we could repair these intermittent no spark conditions and guarantee it to resolve the problem.
Old Jun 1, 2008 | 09:37 PM
Jimmy's Avatar
Global Moderator
You need to check your primary resistance and secondary resistance in your ignition coil and test the ignitor.. even if it's new.
What engine is this on?
Old Jun 2, 2008 | 03:41 AM
1SlowSi's Avatar
Default Re: (Jimmy)
Im actually about to put an ohmmeter on the coil right now lol. This is a stock B16A2
Old Jun 2, 2008 | 09:53 AM
1SlowSi's Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">You need to check your primary resistance and secondary resistance in your ignition coil and test the ignitor.. even if it's new.</TD></TR></TABLE>
I just tried to test it and the multimeter read OVERLOAD which a solid ringing noise. It didnt even give me an ohm load for either of the 2 resistances.
Old Jun 2, 2008 | 03:39 PM
Default Re: (1SlowSi)
sounds like your coil has an open circuit on both sides.
throw a new one in there and see what happens.
Old Jun 2, 2008 | 06:09 PM
1SlowSi's Avatar
Default Re: (PyroProblem)
It was the coil!!! son of a bitch haha. She started right up. thanks for the help! Process of elimination!
lilmisshonda
Jul 2, 2008 09:40 PM
e jay one
Mar 4, 2006 06:02 PM
Crab-Cakes
Sep 4, 2004 04:42 AM
lamont
Nov 3, 2002 05:27 AM
