transmission question
Old Jun 1, 2008 | 04:41 PM
E.'s Avatar
E.
Default transmission question
i notice my car is leaking a little bit of tramission fluit from the right side axle i know i have to replace the transmission seal but witch one the inner or outer ?and i do i have to drop the transmission to replace the seals. Another question is where do i put the transmission fluit at? i notice next to the breather there is a screw that looks like a plug also in the back of the transmission there is a sensor with 2 screw holding it could i put fluit threw those two spots>
Old Jun 1, 2008 | 04:49 PM
BlueIntegraBoy's Avatar
Default Re: transmission question (E.)
The outer axle seal probably needs to be changed. You don't have to drop the tranny to do it.
Part number: 91205-PC9-711
You can fill from the VSS hole.
Old Jun 1, 2008 | 04:56 PM
TODAwhore's Avatar
Default Re: transmission question (BlueIntegraBoy)
just make sure you have the correct fill bolt out, if you fill it up at the vss..just so you wont over fill it..
Old Jun 1, 2008 | 05:25 PM
Default Re: transmission question (TODAwhore)
Tranny takes 2.3 quarts. So, two full bottles and a little more than a quarter of a 3rd bottle.
Old Jun 1, 2008 | 06:00 PM
E.'s Avatar
E.
thanks you what kind of fluit should i used
Old Jun 1, 2008 | 06:18 PM
Default Re: (E.)
I would get Honda M/T Fluid.
Old Jun 1, 2008 | 06:34 PM
E.'s Avatar
E.
thanks
Old Jun 4, 2008 | 02:48 PM
E.'s Avatar
E.
okay so i put in the new seal when i took it off it let loose alot of transmission fluit. after i put the new seal and put the axle back i try to put transmission fluit to but it dint even take one court of transmission fluit what should i do because i know it spill alot when i took the seal off do u think becuase the tranmission was over fill
Old Jun 4, 2008 | 03:20 PM
E.'s Avatar
E.
help please
Old Jun 4, 2008 | 04:09 PM
E.'s Avatar
E.
any one
Old Jun 4, 2008 | 04:49 PM
Montivious's Avatar
Default Re: (E.)
Sounds like you just removed your axle without draining the transmission fluid; you should always drain the trans before removing either axle.
Undo the drain bolt on the bottom of the trans, drain all the fluid out then replace the drain bolt. Torque accordingly. Undo the bolt directly above the drain which is the fill hole. Fill trans with 2.2-2.3 quarts of Honda MT Fluid, basically with the car on a level surface fill until fluid starts running out of the fill hole, then tighten the fill bolt, torque accordingly.
Do this and you should be fine. I'd get a manual, sounds like you may need some tips on axle seal replacement, the Honda manual has a step by step walk through.
Old Jun 4, 2008 | 05:08 PM
E.'s Avatar
E.
thank you i replace the seal i read the book on how to do it. so im just going to drain my transmission becuase i bought tramission fluit from acura so in just going to drain it
Linh.
May 25, 2007 11:07 AM
timmy0tool
Nov 20, 2006 01:31 PM
deviant1
Mar 22, 2005 08:14 PM
Digitalcivic
Dec 22, 2002 09:11 PM
