My car doesn't want to start. Ignition coil maybe?
Old Jun 1, 2008 | 04:13 PM
magicaltrout's Avatar
Default My car doesn't want to start. Ignition coil maybe?
95 GSR.
Stock motor.
Haven't played with the car in the past 6 months.
I took my dizzy apart and the rotor looks like this:
http://i6.photobucket.com/albu...1.jpg
http://i6.photobucket.com/albu...2.jpg
Stupid question since I plan on replacing this either way... Is this normal wear?
I also tested the resistance between terminals A and B and it came out to be 0.7 ohms. The bible says I should be around 0.6-0.8 ohms. Looks normal to me.
Between the A terminal and the secondary winding terminal I have 10.7k ohms, right below the 12.8k ohm minimum.
Is my ignition coil really dead? Is there anything else that could have cause the car to not start all of a sudden? I can't think of anything else to check before I bum a ride to the dealer 30 miles away for parts.
Old Jun 1, 2008 | 07:09 PM
steveo135's Avatar
Default Re: My car doesn't want to start. Ignition coil maybe? (magicaltrout)
Not sure about the rotor but replace it anyway wont hurt...
as for the coil I killed one doing a compression test and when i was testing it the numbers came back that it was good but once i replaced it car fired right up... it probably is bad
Old Jun 1, 2008 | 07:23 PM
Jimmy's Avatar
Global Moderator
Yep.. coil is in spec..
Try testing your ignitior..
Info in this thread..
https://honda-tech.com/zerothread/2306055
How did you determine your not getting spark?
Any cel's?
Can you hear the fuel pump prime?
Old Jun 1, 2008 | 09:23 PM
Default Re: (Jimmy)
Thanks for the link Jimmy. I tested it by taking out a spark plug and cranking it. The coil isn't in spec at 10.7k ohms, but yeah, I just checked the coil and it has a small burn mark on it.
http://i6.photobucket.com/albu...k.jpg
Looks fishy? I'm about 80% sure it's this thing unless that little burn mark is a normal thing.
Old Jun 2, 2008 | 05:09 AM
elmalouno's Avatar
Default Re: (magicaltrout)
most likey your issue. burn marks are not normal on your cars electrical components
shadohconspiracy
Apr 15, 2008 07:47 PM
patrick4588
May 2, 2006 11:41 AM
redintegra1998
Aug 1, 2005 05:30 PM
.M.
Apr 5, 2004 11:04 AM
DSayavan
Jan 11, 2003 08:43 PM
