Fuel pressure
'00 GSR with P30 pistons. Was running lean... Installed an AEM fpr, what should I set the fuel pressure at? And when are you supposed to read it, at idle? With vacum line on or off?
PS: No wideband.
Modified by M2S~Jaime at 4:39 PM 6/1/2008
Modified by M2S~Jaime at 4:54 PM 6/1/2008
Modified by M2S~Jaime at 5:18 PM 6/1/2008
PS: No wideband.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2S~Jaime »</TD></TR><TR><TD CLASS="quote">Cool. Mine was at 44ish but still felt sluggish. How about distributor timing, 16* or 14*?</TD></TR></TABLE>
If I recall, Retarding the timing will give you better top end, advancing timing will give you better throttle response, so give it a shot, just don't go adjusting beyond below 14 or above 18.
yep....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mariohonda(ed6) »</TD></TR><TR><TD CLASS="quote">fuel ratio should be around 14.5 at wide open throttle throughout the power band </TD></TR></TABLE>
And how did you come to this conclusion? ever see what happens to a piston when tuned at 14.5:1 at wot? maybe not right away but in a little time...
Set the fuel pressure to 40 at idle. You need to get a wideband and Netpune or Hondata and a datalogging cable to tune that motor or your going to blow it very shortly.
As a matter of fact you should not drive it around unless you are attempting to street tune it.
97grnrs
Oct 2, 2007 08:47 AM
quick108
Aug 18, 2001 09:20 AM
