1989 hatch a few questions
ok so i have an 89 hatch dx. it so mostly stock. it has a d15b2, im not relay sure what the b2 part means but from what i have herd it better than a b1. it is 5-speed with a cable clutch. interior is clean, the seats don't fit very well but they work i guess. the only thing i have done is seats from, i think, a 97 civic and the shift **** from the same car. a short shifter, the dash clock (i stole it from a junk yard when i was 18 because they wanted 27 dollars for it!! i feel bad about it now
) a lime green intake, which i also feel bad about now, and a spoon header, connected to a 2 1/4'' custom exhaust(none of that loud stuff but a nice sound)
alright, i have a few questions:
i have the parts in the pictures below for the mpfi swap i have:
the manifold,
not sure which one i want to use
wiring harness from an si,
injector box
fuel rail,
injectors but im not sure fi they will work,
a dizzy that im not sure if its the right one,
and a tb that only lines up with 3 of the 4 blots for it on the inmanny. so i think maybe its not the right one?ha-ha
and the pm6 ecu under it
what else do i need. you see, i drive the car so i don't really want it to be out of commission for a long time so i need everything together are all the parts the right ones? i can take more pics if i need and any help or advice is appreciated
Modified by sinepome at 5:11 PM 6/1/2008
Modified by sinepome at 5:20 PM 6/1/2008
Modified by sinepome at 11:33 PM 6/2/2008
the manifold,
injector box
fuel rail,
It looks/sounds like you'll need a wiring diagram to make that si harness interface with the dpfi body harness? If your totally ****, you might need the "mpfi specific" intake manifold brace? Bump for the two-tone paint and the checkered garage floor!!!! FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCRXTURBO20916 »</TD></TR><TR><TD CLASS="quote">WRONG YEAR TB. FIND OUT WHAT YEAR MANIFOLD YOU HAVE.</TD></TR></TABLE>
i dont know there is pic if that helps. i can take more also.
bradmartinfl
Jul 6, 2010 08:24 AM
JMcDB18C
Sep 23, 2008 01:20 PM
JapJunkie
Feb 15, 2004 06:01 PM
