**TESTING THE WATER** Fs/Ft - Rare - Milano Red 1994 Del Sol Vtec--All Motor Build-- $6500
[SOLD.]
Ok Ok, I know I said 6500 is the lowest I will go. But I have found something I want. Therefore the price is adjusted accordingly for a quick sale. New price is 6200.00. There are stock del sol Vtec's going for this. Again, this doesnt include the new sound system or the wheels.
NEW PRICE: 6200.00
OOPS! I did it again... NEW PRICE $$$5800.00$$$
Well guys I'm thinking about selling my Del sol. It is the original 1994 Vtec model that came with the B16. The B16 has been swapped out for an all motor GSR block and SI Head. I bought the car like this, already built, after a girl hit me and totalled my Civic. The previous owner, and original owner, like myself, are extremely cautious/meticulous when it comes to our cars. I have a folder of receipts from the original owners maintenance, as well as receipts for almost every performance upgrade on this list. Everything on this car was done properly, no corners were cut in the build.
Motor & Transmission built by Mike Belben of NEW ENGLAND HONDA REBUILDERS
If you want to see his work, go to http://www.newenglandhondarebuilders.com, you'll be impressed.
Engine:
B18C1 GSR Block - Posted/bored/honed/surfaced Appox. 12-1 compression
81.5 Nippon racing ITR pistons, gas ported, balanced. (Extensive modifications to the pistons, valve relief too much to list)
ITR rods - Shot peen, balanced, resized big ends
ARP rod bolts
Modified oil pump
Plugged oil squirters
Oil galleries modified
Endyn breather kit for PCV replacement & crankcase gas relief.
99 SI B16 Head
Milled to flat quench
Full cylinder head porting
valve job
ARP head bolts/studs
00-01 ITR cams (same as CTR) Degreed in, comes with clearance card/camshaft timing.
ITR valvesprings
Skunk 2 cam gears
5 layer OEM HG
RC 370cc Injectors
Blox Intake manifold - cut open, cleaned up the casting, polished & reweld.
Hy-tech design replica long tube tri-y race header
AEM 3" intake
Transmission:
B16 - Y21
New 1-2 synchro (Never grinded, replaced for preventive maintence)
Limited slip differential
LS 5th gear - For low rpms on the hwy (Good for gas & the motor)
Fidanza 7.5lb flywheel
Action Clutch 1MD - 6 puck unsprung clutch
Exhaust:
2.5" mandrel bent stainless steel piping tig welded by Mike Belben
2.5" flex pipe
2.5" 200 Cell Spun catylic converter from SMSP (way better than the conventional hi-flo honey comb cats) Almost flows like a test pipe.
2.5" resonator
2.5" Flat black vibrant stealth muffler - Clean & Mellow
MISC:
Password JDM red stitch shift boot
Skunk 2 Shift ****
Hasport mounts
Koyo alluminum radiator with slim fan
Skunk 2 sway bars front & back
Skunk 2 camber kit front & back
Tokico shocks
H&R O.E. springs
17" Voxx wheels with decent rubber left
205/40/17 Falken Ziex tires
New NGK v-power plugs (1 step colder)
New OEM wires
New OEM Cap & ITR rotor
New OEM Ignition Coil
Xenocron socketed ECU w/ reburnable chip
Infinity Kappa's in the front & Pioneers in the rear
I recently installed a band new $300 pioneer head unit, as well as Rockford subwoofers, amp, and wiring. If you want to keep this stuff it will be an extra $600 or I can just take it out, no biggie. If i take it out the car will come with a sony Xplod head unit.
Motor & Transmission have been glassedbeaded & cleaned during rebuild. Everything new...OEM gaskets, seals, bearings etc. Everything has been done right. Motor has less than 10k on it, MAX. I have close to 400 pictures of the build on CD. Changed the oil atleast 6 times since break in using only OEM Honda oil filters & the motor only has around 10k on it. Mobil 1 synthetic since break in.
Will last for a long time & take a ton of abuse. 255 psi across the board.
Built to be very resistant to detonation.
The car was tuned at DSG in Norwood. The tune was done 100% for reliability, and the cam gears weren't touched one bit. When it was tuned, it put down 173whp on their awd dyno, which is around 200hp on a dynojet.
Overall the car is in really great shape for its age. the Carpets are unordinarily clean for being 14 years old, as well as the paint. The seats are in ok shape. There is no rips or tears, just slightly faded with a couple stains. Dash isn't cracked, everything works well. I did an extensive cut and buff on the paint, since it was fairly faded/oxidized, and it came out very well. It is still a little faded on the hood, but the car went from chalk board paint to glossy reflective paint. Before and after pics are below.
As far as "problems" with the car, there are only two things that I am aware of, and I wouldn't even consider them to be problems. Sometimes the clutch will squeel at you until it is warmed up. This is due to it being a 6 puck racing clutch, its not meant for daily driving. But once its warmed up, its usually good. Then their is a roaming idle. Which is one of two things: either the IACV, which is a cheap, easy fix. Or it needs the vacuum line for the IM to the valve cover. right now its a hose running from the intake to the valve cover, and the IM is blocked off. Another easy fix.
I try to be as up front as possible to avoid surprises, so if there is anything I haven't covered in this super long ad, feel free to ask. I can be contacted via e-mail, text, phone call, or through h-t. Everything is tied to my blackberry, so if you PM me on here, write in the forum that you PM'd me and I'll get an email saying you did, then i can get back to you asap.
Jesse Arkebauer
207-659-3693
arkebauerj@fc.husson.edu
When I first got it:
After a cut and buff:
AND I am located in Maine. I am willing to meet halfway (within reason) in order to make a deal. There is no question in my mind this car could make a trip around the world without stopping as long as it didnt run out of gas.
I will entertain alot of trades. As long as it is clean and stock/stockish. Let me know what you have if you're interested, the worst I can do is say no.
Modified by needanew1 at 10:17 AM 7/2/2008
Modified by needanew1 at 3:57 PM 7/10/2008
Modified by needanew1 at 12:10 PM 7/16/2008
Modified by needanew1 at 7:45 PM 7/22/2008
Modified by needanew1 at 12:46 AM 7/31/2008
Modified by needanew1 at 2:45 PM 8/1/2008
Modified by needanew1 at 1:47 PM 8/9/2008
NEW PRICE: 6200.00
Engine:
ARP rod bolts
Modified oil pump
99 SI B16 Head
valve job
ITR valvesprings
Skunk 2 cam gears
5 layer OEM HG
RC 370cc Injectors
AEM 3" intake
Transmission:
B16 - Y21
Exhaust:
2.5" flex pipe
2.5" resonator
MISC:
Skunk 2 Shift ****
Hasport mounts
Tokico shocks
H&R O.E. springs
New OEM wires
Jesse Arkebauer
207-659-3693
bump since im mike belben neighbor and he rebuild my tranny and its a beast way better then the itr i had thanks sick car good luck selling it...
Thanks for the bump, theres no question about it, mike belben is an artist when it comes to builds.
And, the price is BO, I don't want to take 3 months to sell it so if you have cash and are interested, let me know!
When it was tuned on the dyno at DSG, which is an awd, honda heartbreaker dyno, it put out about 173 WHP and 125 WTQ, thats on an AWD dyno. On a regular dyno, it would be about 200 whp i believe, but i have yet to get it on one. With cams, you can expect around 230whp.
I can get a copy of the dyno sheet on here tommorow.
Copied that right over from my ad in the vehicle for sale section!
i want this car soooooo bad.i wanted it when the last guy was selling it.would you take a 93 civic hatch cx with a few small mods a honda ruckus and 2000 cash?let me know brendondesmond@tmail.com
Hey man, Thanks for the interest in my car. But unless I get a trade for a clean EM1 or bb6 I'm probably going to be getting out of the game this time around.
Sell that stuff and buy my car?
lmao yea i want that baaad.my integra i tryed offering you got stolen and i ended up buying that hatch and the ruckus.but i sold em both so i wanna try an catch it this time around.email me at brendondesmond@tmail.com because if you pm'd me then it didnt go threw cuz of my gay pc.let me know thanks.
