cracking crossmember?
Old Jun 1, 2008 | 11:54 AM
rexfan's Avatar
Default cracking crossmember?
yea I had this cracking noise ever since i can remember... when i break or when i do sharp turns, it does that. Ive changed a lot of things on it, motor mounts, rotors, pads, calipers, knuckles, upper and lower control arms. I also have the innovative mounts cross member, i don't know if that is the thing that is making the sound. the sound is like when something is really stiff and it gets moved, it tends to crack, it sounds like a stiff crack lol, if u guys know what i mean, help me out... thanx.
Old Jun 1, 2008 | 07:15 PM
~sp33~'s Avatar
EFB055
Default FV-QR
Im going to bump this, sounds similar to whats going on with my car. I've been told it may be the radius rod bushings which subside in the front cross member, im still yet to check that out though.
Old Jun 1, 2008 | 07:43 PM
zrickety's Avatar
Default Re: FV-QR (~sp33~)
same here...it's intermittent (i think) but happens when braking and accelerating. i have the full-race crossmember, so i'm pretty sure it's not the radius rods, but aside from that, i've found nothing on the car
Old Jun 1, 2008 | 10:02 PM
rexfan's Avatar
Default Re: FV-QR (zrickety)
well i am going to check it out tomorrow and ill tell you what i find out. My cousin thinks it's the axles but i doubt it... i am going to tear apart all the front passenger breaking assembly tomorrow because of another problem, but ill let u guys know what i find out, see ya.
Old Jun 2, 2008 | 04:40 AM
~sp33~'s Avatar
EFB055
Default FV-QR
It wasn't the actual rods, it was the bushings at the end of the rods? So the mechanic guy said. I'm still yet to check it out.
As you guy's have said though, it only happens when im turning lock to lock, or braking, or any kind of weight shift (Not speed dependent).
EG6lovin06
Oct 3, 2013 01:15 PM
HondaGuy951
17
Jan 8, 2009 06:31 PM
KhmerdudeSiR
12
Nov 13, 2008 06:23 PM
ridestrt
May 18, 2004 09:27 AM
Jester88Si
Jan 15, 2004 10:28 AM
