wiring PW0 harness to OBD1 connectors for Hondata S300
hi guys,
Hi guys,
I've rewired the entire harness to OBD1 plugs. I"ve used this diagram for reference. But i have a few questions, as the OBD0 wiring on this site is not the OBD0 PW0 which i'm using now.
http://www.boosted.org/ecu/COMPLETE.txt
here is the pinout for PW0 ecu.
http://hondaswap.com/reference...28667/
question
1.) My EF8 harness has 2 pins for the ignitor. B15 and B17. which should i use? Should i just cut off the other?
2.) A16 alternator to B5 for alternator. But the PW0 pintout, B5 is oil pressure switch. so i connect D6 to B5 instead?
3.) PW0 pin B20 ignition adjustment connector, should i use it?
4.) D10 electric load detector. ELD what is this? It says connect to B19, but its the knock sensor. what pin should i use?
5.) A12 engine coolant temp switch to B4,but this pin is not there.
hope you gurus can help me out. thanks!
Hi guys,
question
ludesrv
Sep 3, 2006 08:21 PM
K-Drum
Jun 6, 2005 08:06 AM
