took head apart head apart...WHITE valves??!!
Old Jul 16, 2002 | 10:52 AM
JDM_ITR's Avatar
Default took head apart head apart...WHITE valves??!!
took my head apart to change out valves......and all my exhaust valves were bright white....what does this mean? Am i running to lean? from the flat part of the valve to about half the stem...all pure white...and the are OEM valves......what is going on?
sgT's Avatar
sgT
Default Re: took head apart head apart...WHITE valves??!! (JDM_ITR)
means nothing
Old Jul 16, 2002 | 10:54 AM
JDM_ITR's Avatar
Default Re: took head apart head apart...WHITE valves??!! (sgT)
so this is normal? ive opened up other heads and never seen white valves before.... well, guess i got nothing to worry about then.
Old Jul 16, 2002 | 04:32 PM
Slick GS-R's Avatar
mine were't white.......check it out @ my website: http://web.bryant.edu/~ajp4/galleryhead.html
Old Jul 16, 2002 | 05:02 PM
Slick GS-R's Avatar
Default Re: took head apart head apart...WHITE valves??!! (DragonCTR69)
thats my B18C1 head with the broken valve......too much timing with spray (i'm retarded>>>>i got greedy because i made 30 WHP more than when it was advanced that much) too bad the motor didn't like me too much after that
Old Jul 16, 2002 | 06:32 PM
MiraiZ's Avatar
I think it means that your running a bit lean, but you should only be really concerned if your pistons and/or plugs look whitish too...if they look okay then don't worry about it
Old Jul 16, 2002 | 07:26 PM
dustin's Avatar
Default Re: took head apart head apart...WHITE valves??!! (MiraiZ)
doesn't mean anything. I have 3 entirely stock LS heads here and all the exhaust valves are white.
same with my gsr head.
Old Jul 17, 2002 | 05:25 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: took head apart head apart...WHITE valves??!! (dustin)
when we had to tear apart my head, my valves were white as well. I'm assuming it's running lean...That's what my did...
chad
Jul 7, 2011 09:27 PM
JMinSi2000
Aug 16, 2004 08:11 PM
Quetzolcotl
Aug 30, 2003 09:59 AM
