Air Conditioner Squeaking/screeching
Old Jun 1, 2008 | 09:15 AM
invisible's Avatar
Default Air Conditioner Squeaking/screeching
my a/c just started screeching loudly when i have it on. its does it randomly, on and off. all belts were changed not too long ago, maybe about 3-4 months. could it be the belt? im going to take a look at it later, its 100º+ out right now...
Old Jun 1, 2008 | 05:26 PM
invisible's Avatar
Default Re: Air Conditioner Squeaking/screeching (invisible)
help
Old Jun 1, 2008 | 05:35 PM
biker9075's Avatar
Mine does the same thing
Old Jun 1, 2008 | 05:36 PM
elektronsi's Avatar
check the belts, had the same problem a while back after changing the belt, got some of that grease **** or whatever it is they sell at checker (or wherever it is you go) to stop the squeaking
Old Jun 1, 2008 | 07:42 PM
TheJGB3's Avatar
Most people use "belt dressing" it's kind of like WD-40. You spray it on the belts every so often to get rid of the squeal.
Old Jun 1, 2008 | 08:55 PM
civicseth's Avatar
Also, you probably want to tighten your belt up a little more. Exact same thing that happened to me, and I actually just tightened my belt up today. Haha. It stopped the squealing.
Old Jun 1, 2008 | 08:58 PM
Hanmin's Avatar
my belt started to squeal after i got it wet=].
Old Jun 1, 2008 | 09:38 PM
invisible's Avatar
Default Re: (Hanmin)
thanks guys. ill tighten it up tomorrow and see if that does the trick.
scottmog
Dec 18, 2008 09:15 PM
amej8
Jun 1, 2007 09:00 PM
silvercivichatch
Dec 20, 2004 06:45 PM
HamiltonRex
10
Nov 13, 2004 04:32 PM
J T*
14
Apr 5, 2002 06:21 PM
