Need Help ASAP!!!!
Old May 31, 2008 | 09:20 PM
DC2Integrals's Avatar
Default Need Help ASAP!!!!
Ok so heres the deal, i have a 96 civic hatch with a jdm type r motor swap in it. I changed my oil last sat. and right after that drove it to the store. On the way there my check engine light turned on, which was weird because its never happened in the past. When the check engine light is on the engine feels a little sluggish and vtec is not that strong. When I turn the car off the check engine light turns off and when i turn the car back on, i have to drive a little bit before it turns back on. So today I brought it to a shop to run a diagnostic test on it and the device cant read anything from the obd. He checked all the plugs and connections just in case and couldnt find anything wrong. I left the shop and when I was going to pull out of the parking lot I noticed that the engine was idling weird. It would jump from 900 rpm all the way up to 1500 rpm and then back down then backup again and then came to rest at 800-900 rpm. I've checked the spark plug as well as the wires, nothing wrong with them at all, so im out of ideas... Any help would be greatly appreciated!!! I want to try everything before I go to my local import shop and pay a **** load of money to get my car fixed... Thanks again...
Old Jun 1, 2008 | 09:29 AM
Default Re: Need Help ASAP!!!! (DC2Integrals)
need help...
Old Jun 2, 2008 | 03:53 PM
PyroProblem's Avatar
put a jumper wire in the service connector and check codes. this will point you in the right direction...
check the FAQ's at the top for more info on how to check codes and look them up.
Old Jun 2, 2008 | 06:08 PM
Agnom's Avatar
Are you running OBD1 or OBD2 ecu?
Old Jun 2, 2008 | 07:00 PM
averyvm's Avatar
Default Re: Need Help ASAP!!!! (Agnom)
and having a jap spec computer would be difficult for shop to scan
Old Jun 3, 2008 | 07:21 AM
92civic_hatch's Avatar
are you leaking any of your new oil, from anywhere?
Old Jun 3, 2008 | 10:31 AM
Default Re: (92civic_hatch)
I tried geting a diagnostic test but it wont read.
Im running an obd1 ecu
No oil leaks as of yet.
Old Jun 4, 2008 | 02:40 AM
Default Re: (DC2Integrals)
Our US spec OBD 2 scan tools will not read JDM ecu's, however the self check does still work with the jumper wire...
Same thing happened to me when I swapped in a jdm ITR swap into my 98 hatch...
Old Jun 4, 2008 | 02:54 AM
Battle2.0Eg's Avatar
Default Re: (PyroProblem)
It sounds as if a live squirrel is making things difficult
Take it to the dealer
dd69ma
16
Jun 17, 2019 04:11 AM
xlusiveracer
45
Dec 17, 2011 12:59 AM
vaerio81
Sep 3, 2007 10:23 AM
dd69ma
Feb 1, 2006 07:58 PM
dd69ma
Feb 1, 2006 07:55 PM
