VALVE ADJUSTMENT Help
I was just wondering if there are special tools to adjust valves on my 96 GSR, and where i can get a hold of those tools. I've seen people do it with screw drivers but that seemed to be a pain.
Oh and some Do's and Dont's on a valve adjustment. Thanks
do a search on valve adjustments... there are special tools for this. there's one with a screwdriver and a hexdriver/wrench combined. you can also get a special wrench that's bent for the correct angle. or you can get a wrench and have it bent. i would definitely do your homework before you attempt this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama »</TD></TR><TR><TD CLASS="quote">do a search on valve adjustments... there are special tools for this. there's one with a screwdriver and a hexdriver/wrench combined. you can also get a special wrench that's bent for the correct angle. or you can get a wrench and have it bent. i would definitely do your homework before you attempt this.</TD></TR></TABLE>
X2
And
X2
And
just did mine last week with just a hexdriver/wrench and a screwdriver plus those things ^^^^he posted i don't know what they are called...of course i was under supervision by a pro and he walked me through it...its pretty simple and straight forward once you get the hang of it
those are feeler guages, i jut did mine yesturday morning for the first time, very easy to do and i believe the special tools are like $50 its way cheaper to just bend a wrench. just takes a little longer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wastedyouth2542 »</TD></TR><TR><TD CLASS="quote">those are feeler guages, i jut did mine yesturday morning for the first time, very easy to do and i believe the special tools are like $50 its way cheaper to just bend a wrench. just takes a little longer.</TD></TR></TABLE>
WTF?
http://www.partsamerica.com/Pr...48827
WTF?
As already stated..
You need a feeler gauge and here is a write up:
http://www.c-speedracing.com/h...t.php
definitely buy the tool it's amazing what such a small clearance difference can do... it's very simple to do my car ran like
after i built my motor, my friend came over and told me i needed to adjust the valves, he taught me, 15 min later my new motor purred like a kitten.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">As already stated..
http://www.c-speedracing.com/h...t.php</TD></TR></TABLE>
x2. follow that guide like a christian to the bible, you won't go wrong. it walked me through my first valve adjustment
bseries_beast
May 12, 2007 12:44 PM
)you get your money back
