Battery light
Old May 31, 2008 | 06:26 PM
batallic's Avatar
Default Battery light
if i rev to 3500 rpm the battery light turns on, alternator and battery are 3 months old,
d16z6,
Old May 31, 2008 | 07:07 PM
shaggs's Avatar
how old is the drive belt??? sounds like you have to much play in it
Old May 31, 2008 | 07:53 PM
batallic's Avatar
Default Re: (shaggs)
i think that was changed with the alternator i have to check
Old May 31, 2008 | 10:19 PM
itsmejto's Avatar
Default Re: Battery light (batallic)
Belt tension, it's slipping, too loose.
If it was a new belt it has stretched a little and needs re-tensioning.
Or you have a flakey alternator or connector.
I believe the battery light can come on on over voltage too (not sure) which means you may have a flakey battery or alternator (either or both).
Connect a dc volt meter to the battery and check voltage while reving 3500, if it goes way above 14.2 with lights etc on it's your regulator circuit, which may be in your ecu (expensive) Idle should be arround 12.8 to 13.8 vdc loaded. Then try it again with no load. Check for high or low voltages out of these specs.
Old Jun 1, 2008 | 12:49 AM
batallic's Avatar
is there a way to tighten the tensioner
Old Jun 1, 2008 | 02:04 AM
batallic's Avatar
i just checked the belt, theres just a little bit of play
Dafredsta05
Aug 31, 2016 09:53 AM
ElCivic89
Mar 27, 2012 08:23 PM
da9pwnsu
Jan 19, 2007 12:12 PM
fe519
Sep 23, 2003 03:25 AM
crxtreme27
11
Aug 28, 2002 11:29 AM
