rebuilt transmission problems need help fast
i just had my transmission rebuilt while i was at college. The rebuild was done by other students and i was not present during the entire build. I just installed the trans into my hatch and now when i put the shifter into neutral it is actually in 1st and when i put it where second it is in neutral and i cant go any farther back. after this i cant get it to go in any other gear and now im swapping trans back so i want to know what to look for once i tear it apart myself i know it is most likely something wrong with the internal shift linkage. Thanks
no shift linkage is not bent because i used it on first transmission and had no problem so i have to take it apart in a lil bit i guess
Well im not a rebuilder, just used to be a R&R guy but if you ask me it could be a ton of things.
Now ive seen tranny's where shift solenoids were in the wrong spot and it caused every problem you can imagine, or a valve body that didnt get cleaned properly and it did somewhat what you're describing, theres a reason you dont let a bunch of students with probably zero actual experience rebuild a automatic transmission.
If you can get in touch with them see if they'll help you, but unless its something simple i think your going to have to take it to a shop for another rebuild.
bee16a
Jan 10, 2006 01:21 PM
