need help with oxygen sensor b18a swap
Old May 31, 2008 | 01:31 PM
flipdrift's Avatar
Default need help with oxygen sensor b18a swap
hi i have a 91 civic dx hatchback that has a b18a swap i dont know were to plug in my O2 sensor it has 4 wires and the comp has one wire sticking out with a peice of tape on it stated O2 can you please help?
Old May 31, 2008 | 08:40 PM
Hybridize's Avatar
Default Re: need help with oxygen sensor b18a swap (honda-tech-sucks)
Obd1. Gotta use the 4 wire.
Search and find a pinout for an obd1 ecu. You'll see which pins you need to splice/add to.
Old May 31, 2008 | 11:02 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: need help with oxygen sensor b18a swap (Hybridize)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybridize &raquo;</TD></TR><TR><TD CLASS="quote">Obd1. Gotta use the 4 wire.
Correct. OBDI uses a better 4 wire heated o2 sensor for accurate readings. There's a reason Honda upgraded from the single wire non heated version.
grey_ghost
Dec 2, 2007 09:54 PM
dougshatch
Jun 11, 2007 06:38 PM
Mach69
Dec 21, 2004 08:16 PM
civtegra_hybrid
Sep 14, 2004 01:15 AM
88crx Osaka
Jul 28, 2003 05:02 PM
