Cam gear setting for stock timing
I have a question about the timing and setting for the cam gears. I've turned the crank until the number 1 piston is at TDC but I'm unsure of how the cam gears should go. Should the "Up" indicators be going straight up or should they being going in a generally up direction with the notches on the gears lining up all the way across? I hope that's a clear as it sounds to me. Any help at this point would be great.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A L I A S »</TD></TR><TR><TD CLASS="quote">the arrows on the cam gears should be pointing to the sky!!!</TD></TR></TABLE>
x2
x2
9honda5civic
Oct 10, 2012 03:21 AM
Brewer
Feb 2, 2005 10:48 AM
