2000 Honda Civic EX 3-piece OEM Air box
Old May 31, 2008 | 12:39 PM
00Civic128's Avatar
Default 2000 Honda Civic EX 3-piece OEM Air box
I lost my 3-piece air box for 2000 civic and i just won a bid on ebay for a Honda Civic Ex 1999 Air Box. I think that it's the same one but i just wanted to make sure that this one will fit a 2000. Thanks.
Old May 31, 2008 | 12:41 PM
yusojdm's Avatar
same
Old May 31, 2008 | 12:45 PM
00Civic128's Avatar
Default Re: 2000 Honda Civic EX 3-piece OEM Air box (00Civic128)
Cool, thanks a lot.
Will it help with my mpg once i put the oem back? I have a cheap-o intake and would like to increase my gas mileage even by just a little bit.
Old May 31, 2008 | 12:47 PM
yusojdm's Avatar
dont think its really that noticeable if its stock.
Old May 31, 2008 | 04:20 PM
NOFX's Avatar
H-T White Ops
It might help you not lead foot it so much.
If you want to change your driving habits, start logging your gas mileage on a site such as gassavers.org.
My last tank on my '98 EX coupe was 35.88 mpg and it's only getting better since I started recording (started with about 28mpg and only have changed driving habits so far - could use a tune up).
Old Jun 1, 2008 | 04:41 PM
00Civic128's Avatar
what would be the oldest year the OEM air box compatible with my model? I see that the 1998 air box looks similar as well.
Old Jun 1, 2008 | 04:45 PM
Ice78transam's Avatar
Default Re: (00Civic128)
I believe the 96-97 box will fit as well. Honda is smart, not too much differentiation between parts. After all, it was the invention of interchangeable parts that sparked the industrial revolution.
Old Jun 1, 2008 | 04:48 PM
t0p_sh0tta's Avatar
The 99-00 are identical. There may be slightly different sensor placement with the 96-98 boxes (I'm unsure), but I'm sure you could get them to work.
Don't expect to gain anything by going back to the stock box. You're better off changing your driving habits and checking your tire pressure.
What are the specs on your setup?
Old Jun 1, 2008 | 06:48 PM
00Civic128's Avatar
Everything is stock except for the bolt on exhaust, lowering springs and shot ram intake.
Old Jun 1, 2008 | 07:44 PM
TheJGB3's Avatar
Just remember to get an airbox from an EX (D16Y8) all other Civic models had a different engine and a different airbox..
pascal514
Jul 28, 2009 10:40 AM
Teglessb18
11
Jun 12, 2008 07:31 PM
Trellis
May 27, 2006 10:24 AM
OneCamIsEnough
Jan 17, 2005 08:42 PM
HJ2kcivic
Feb 19, 2003 03:40 PM
