Tranny Question for b20/vtec
Old Jul 16, 2002 | 09:25 AM
kmf0211's Avatar
Default Tranny Question for b20/vtec
I plan on getting a b20 longblock only along with a b16a2 or b18c1 head..I have 2 questions now...
I can get a GSR hydro tranny for about 400 - 700...Is a gsr tranny a good tranny for this swap??
Also - What pistons do you guys recommend?? In all the B20 posts i have read most of you guys have recommended better pistons...Im not looking to go crazy and build the block rite away...I would just like to put better pistons in while im swapping the heads...
Any recommendations are greatly appreciated!!!!!!
Thanks in advance guys
Old Jul 16, 2002 | 09:49 AM
B96v6's Avatar
Default Re: Tranny Question for b20/vtec (Hatch_92)
GSR is probably the best tranny for the swap. The B16/Type R trannys have a close gear ratio that would not benefit you (run through your powerband way to fast). LS tranny's have a long gear ratio that really isn't a good choice unless you're going FI. Remember, CRVTEC engines have a healthy torque curve in the middle of the band, so you don't need to run at such high RPM's as a B16 or Type R.
B96v6
Old Jul 16, 2002 | 09:51 AM
BROOD's Avatar
I am using a GSR transmission on my CRVtec. I'm gonna keep using it after the turbo is installed also, it should work fine for me. I'm not keen on using the LS trans at this point. It is a judgment call.
If you want to put better pistons in you might as well do the whole thing correctly. LSVtecs and CRVtecs are not the best when thrown together. You can make a list of all the high points with some quick searching.
Good luck with your project
[Modified by SLPR, 10:56 AM 7/16/2002]
Old Jul 16, 2002 | 09:55 AM
kmf0211's Avatar
Default Re: Tranny Question for b20/vtec (SLPR)
thanks a lot guys.....
Im gunna take your word about how Ls/Vtec or Cr/Vtec motors arent great when they are thrown together....Im not very familiar with building motors or stuff like that my last swap i did wasjust an LS swap into my 92 SI that i did with my brother who is very familiar with doing swaps...any suggestions on what to do to this motor then??
Old Jul 16, 2002 | 11:02 AM
blufke's Avatar
turbo
Old Jul 16, 2002 | 11:06 AM
kmf0211's Avatar
Default Re: Tranny Question for b20/vtec (blufke)
should i bother wasting my money on a Vtec head...I would probally save the 500 - 1000$ and build it up and then boost it....
any suggestions?
t3st
Nov 8, 2006 02:27 PM
eeekthehatch
Dec 4, 2002 07:32 AM
awskalis04
Nov 15, 2002 07:41 AM
g's integ
Sep 19, 2002 03:12 PM
