!!!!!!Plz PLz i need help with building up my d15b!!!!!!
Old May 31, 2008 | 08:23 AM
Big J EK9's Avatar
Default !!!!!!Plz PLz i need help with building up my d15b!!!!!!
ok so im planning on rebuilding my head (camshaft,cam gear, valve spring,retainers,etc) and also later on my block (pistons,rods,crankshaft) but i cant find anywhere at all where they sell upgraded parts for a d15b....everywhere i go says for d series y and z6....i want to know which d series parts fit on my jdm d15b?
Old May 31, 2008 | 08:36 AM
Big J EK9's Avatar
Default Re: !!!!!!Plz PLz i need help with building up my d15b!!!!!! (Big J EK9)
plz man everyone....
Old May 31, 2008 | 08:42 AM
rSol93's Avatar
Chill out? D15 parts arn't very common.
Old May 31, 2008 | 08:53 AM
Big J EK9's Avatar
Default Re: (rSol93)
so ne idea were i could find any at all tho?
Old May 31, 2008 | 09:00 AM
boondocks1805's Avatar
Default Re: (Big J EK9)
I was having the same problem man adapt and overcome everything im am using to build my D15 is coming from D16's just trial and error
Old May 31, 2008 | 09:09 AM
wmac's Avatar
d15b vtec uses d16 rods and it's own crankshaft . unless its damaged use the crank you have.
rod bearings = d16, main bearings = d15
all d pistons will 'fit' 75mm. different ones will give you different compression
head is the same as z6.
what kind of build did you have in mind?
Old May 31, 2008 | 11:48 AM
95 honda8's Avatar
Default Re: (wmac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wmac &raquo;</TD></TR><TR><TD CLASS="quote">d15b vtec uses d16 rods and it's own crankshaft . unless its damaged use the crank you have.
Old Jun 5, 2008 | 07:55 AM
Big J EK9's Avatar
Default Re: (95 honda8)
i was planning on upgrading the cam,valve springs, and retainers maybe skunk2? idk
Old Jun 5, 2008 | 08:15 AM
wmac's Avatar
the head is the same as z6 head so you can use z6 parts. Crower or Zex(Competition Cams) can be found on ebay. someone on here broke their Crower cam, but generally i heard good things about them
civicxxman
Feb 10, 2008 10:48 AM
opelorc
Sep 12, 2007 10:46 AM
opelorc
Sep 11, 2007 11:12 PM
PlayDepot
Jun 2, 2005 07:06 PM
Btothe3rdDegree
14
Mar 2, 2004 11:31 AM
