Is a stock 2000 Si radiator sufficient to cool B18C1?
Old May 31, 2008 | 05:16 AM
4EN[sic]'s Avatar
Default Is a stock 2000 Si radiator sufficient to cool B18C1?
I am having some over heating issues. Doesn't happen all the time, only on really hot days. I heard that the stock civic radiator can't handle a B18 since the GSR radiator is extra long and has higher cooling capacity. Anyone else have any issues with a stock civic radiator?
Old May 31, 2008 | 06:11 AM
gibsanez's Avatar
Default Re: Is a stock 2000 Si radiator sufficient to cool B18C1? (4EN[sic])
My stock D15 rad cools my H22 just fine, so I doubt that's your problem.
Old May 31, 2008 | 06:41 AM
delslo93's Avatar
Default Re: Is a stock 2000 Si radiator sufficient to cool B18C1? (gibsanez)
My stock d15 radiator cools my turboed b16 (but has trouble on the highway). Check to see if you have air in your coolant lines or possibly a bad head gasket.
Old May 31, 2008 | 07:32 AM
90_EX_Civic's Avatar
Default Re: Is a stock 2000 Si radiator sufficient to cool B18C1? (delslo93)
^^ that and make sure the fins on the radiator aren't smashed for dented.
Old May 31, 2008 | 07:39 AM
gsrhatch2356's Avatar
if you have a way of testing temps then you should check upper and lower hoses it should drop atleast 20 degrees from upper to lower. if not the radiator is bad and make sure the vehicle is at operating temp before doing this test.
Old Jun 1, 2008 | 05:26 AM
4EN[sic]'s Avatar
Default Re: Is a stock 2000 Si radiator sufficient to cool B18C1? (gsrhatch2356)
Thanks for the suggestions everyone.
mikep_95133
May 10, 2009 03:14 PM
misternguyen
12
Aug 6, 2008 12:01 PM
bootlegtrader
Jul 31, 2005 10:54 AM
DaeDae12
Jun 12, 2002 06:19 PM
