transmission fill bolt stuck! need a work-around
Old May 30, 2008 | 10:45 PM
Corksil's Avatar
Default transmission fill bolt stuck! need a work-around
Hey I have a 1.5L crx dx (1988) and I drained the tranny fluid (manual) to change it and I can't get the filler bolt out. It's stuck and my 11/16" wrench isn't working.
Is there any kind of work-around for this bolt? I heard something about the speed sensor hole but I can't find it.
I drained the oil first, so until I figure this out, I can't drive anywhere. Thanks for posting.
Old May 30, 2008 | 11:05 PM
90sedan's Avatar
Default Re: transmission fill bolt stuck! need a work-around (Corksil)
Is it stuck, or stripped? If it is just really tight try using a breaker bar along with the 17mm wrench. If it is stripped, you can fill the transmission through the reverse sensor. Its a 19mm sensor that has the two wires coming off of it. Its located on the top near the front of the transmission.
It takes ~ 1.8 quarts.
Old May 30, 2008 | 11:22 PM
Corksil's Avatar
Default Re: transmission fill bolt stuck! need a work-around (90sedan)
thanks so much for the response.
could you describe the reverse sensor more? when you stand in front of the tranny looking down at it, where is it? I can't seem to find what you're talking about but I'm dying to get it fixed!
Old May 30, 2008 | 11:27 PM
beana's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corksil &raquo;</TD></TR><TR><TD CLASS="quote">It's stuck and my 11/16" wrench isn't working </TD></TR></TABLE>
why are you using sae tools on a metric bolt it's 17mm
i could go on a rant but i won't
loosen the reverse sensor (try wd40 or pb blaster to bust it) take your 3/8 ratchet and pull out the fill plug on the side the diff fill it with 10w/40 untill it comes out the fill plug put the reverse-o sensor back in and then the fill plug BAM you're done
Old May 30, 2008 | 11:39 PM
Hadtstec's Avatar
Easy!
You can fill the Gearbox through the breather hole at the top! Get a funnel and a tube that fits over flush.
It will take around 20mins to fill
Old May 31, 2008 | 12:03 AM
Corksil's Avatar
Default Re: (Hadtstec)
thanks lots for the replies!
I ended up getting the fill plug out w/a 17mm from the top with a cheater bar on it...
Next time I go out i'll get some pb, so next time it won't take as long.
Yup, no more SAE tools for me, i get it.
Thanks again
andrewsmith85
19
Jul 25, 2008 11:58 AM
GarageAlchemist
19
Aug 18, 2006 11:23 AM
PearlBlueType-S
14
Mar 21, 2006 08:41 PM
Mackenzie
12
Oct 30, 2004 07:49 PM
araknis
Apr 10, 2002 03:38 PM
