Guys with Tein RAs!!
Old Jul 16, 2002 | 08:41 AM
done's Avatar
Default Guys with Tein RAs!!
What is your damping settings???
mine is currently set at 10 all the way around.. i thinking about front 8 and rear 10......
Old Jul 16, 2002 | 08:56 AM
tonyxcom's Avatar
Default Re: Guys with Tein RAs!! (Jordo)
Damn, are you trying to disembowel yourself?
I am running 3f 1r
Old Jul 16, 2002 | 09:00 AM
done's Avatar
Default Re: Guys with Tein RAs!! (tonyxcom)
What would be a godo settin for auto x??
i thought its better for front to be softer then rear end...
Old Jul 16, 2002 | 09:01 AM
Reid's Avatar
Global Moderator
Just go to autox and find out.
Set it up there.
What are your spring rates?
Stiff dampening with soft springs is pretty useless.
Old Jul 16, 2002 | 09:14 AM
Asahi's Avatar
for auto-x start the fronts on 8 and then adjust the rear stiffer until you get oevrsteer. I usually go about 8f/12r. If it doesn't want to oevrsteer I got up 2 clicks at a time.
Make sure you are turning clockwise to stiffen and that full soft is counterslockwise till it stocks.
For street I run 3f/4r
Old Jul 16, 2002 | 09:16 AM
done's Avatar
Default Re: Guys with Tein RAs!! (Reid)
whatever springs come on tein Ras
Old Jul 16, 2002 | 09:17 AM
done's Avatar
Default Re: Guys with Tein RAs!! (Asahi)
ill try that...
Reid's Avatar
Global Moderator
Do you know the rates?
Switch the springs. (i.e. put the fronts on the rear and vice versa)
If they're the standard RA springs, the fronts will be a higher rate than the rear.
Old Jul 16, 2002 | 09:21 AM
done's Avatar
i dont have a clue, ill find out though..
Asahi's Avatar
The RA's come with
14kg/mm or 783lb/ft Front
and
10kg/mm or 559 lb/ft Rear
Trick for adjusting shocks is to keep the front 1/2 stiff or less if possible to keep good rebound so the tires will make good contact and then messing with the rears as needed. Like I mentioned I start at 8/12 and change the back as needed. if you get to 8/16 and still have too little oversteer turn the front down a little. If that doesn't do it go to tire pressure.
I had an issue with too little oversteer at 6/16 this weekend at an auto-x but I have stickier tires on the back than front. it took running 38 psi front and 33 psi rear to get it to rotate.
Old Jul 16, 2002 | 09:23 AM
Asahi's Avatar
Sawapping them is a good option. THey are both 200mm (8") so height isn't a problem. I have the HA's and the rear spring rate is 335 and the front is 445 and I am not sure 335 is high enough for the front to warrant 450 in the rear . . .
Old Jul 16, 2002 | 09:26 AM
done's Avatar
thanx alot...
im a major beginner, this will be my 1st auto x.. soo im gonna try to find a good setting just to learn how my car reacts...
Old Jul 16, 2002 | 09:27 AM
Asahi's Avatar
what tires will you be racing?
Old Jul 16, 2002 | 09:30 AM
done's Avatar
re10s stock tires..
Old Jul 16, 2002 | 09:34 AM
Asahi's Avatar
cool. run 40 psi and watch sidewall roll over.
Old Jul 16, 2002 | 09:35 AM
done's Avatar
is that good???
Old Jul 16, 2002 | 09:37 AM
Asahi's Avatar
no. if you see the tire wearing our over onto the sidewal you up the air pressure. Find a good FWD guy to ask about stuff.
Old Jul 16, 2002 | 09:56 AM
Muckman's Avatar
Moderator in Chief
Usually at autocrosses you see people running with lines of shoe polish marked on the tread and over onto the sidewall.. that way you can use the line as an indicator of how much the tire is flexing and thus adjust your tire pressure... The more flex, the more shoe polish will be rubbed off the sidewalls. Give that a shot.
Old Jul 16, 2002 | 12:14 PM
00MRSi's Avatar
Default Re: Guys with Tein RAs!! (Muckman)
Asahi, Muckman, very informative thread.. Thanks..
John: who's saving up for TEINS for the future...
jack-gtir
Suspension & Brakes
Sep 20, 2007 07:00 AM
hybridcrx
21
Apr 1, 2004 09:40 AM
hybridcrx
Mar 16, 2004 01:43 PM
lustedp
Oct 22, 2003 03:05 AM
sublimnal
Sep 12, 2002 01:33 PM
