itr spoiler & battery question
Old May 30, 2008 | 07:55 PM
SkaiWu's Avatar
Default itr spoiler & battery question
i believe the holes i circled in red are the correct ones... the ones in black incorrect
correct me if i am wrong
<u>timeline</u>
1) came spoilerless w/ no 3rd brakelight (billion holes on trunk and quarter panel) weight reduction
2) put on 3 piece for 3rd brakelight
3)took off 3 piece because i have acquired a 3rd brake light
4) awaiting to put on itr spoiler
5) also my battery died, whats a good place to change/get a battery w/o bS in fremont/unioncity/newark region
(never had to change battery, thanks)
is there suppose to be that much of a distance between spoiler sitting position and end of trunk? yes i know there is suppose to be a distance but i do not know how far it is legitimately
i have more holes on the quarterpanel as well...
how it currently sits
Old May 30, 2008 | 08:11 PM
Db1_77's Avatar
Default Re: itr spoiler & battery question (SkaiWu)
there is a little bit of a gap between the back of the spoiler and the end of the hatch. This is because the spoiler design puts the top of it hanging over the trunk just a tad.
I'd suggest measuring (nd then mirroring to the other side of the trunk) from the holes you showed in this picture:
-jonathan
Old May 30, 2008 | 08:28 PM
SkaiWu's Avatar
yea the other side has holes lined up differently so im gonna need to do some hole drilling as shown on the first few pics (correct me if im wrong on those red circled spots i have to drill out)
(still dunno a place to do a battery deal)
Old May 30, 2008 | 11:09 PM
Db1_77's Avatar
If you buy a battery from Advanced Auto or Autozone, usually they'll install it for free.
Its almost impossible to tell from the pictures where you need to drill exactly. Just take a simple ruler and measure exact dimesions from a point of reference and you'll be fine.
-jonathan
Old May 31, 2008 | 03:22 AM
J. Funk's Avatar
I think its the black ones. The red ones are for the wires on the stock spoiler. I might be wrong though.
Old May 31, 2008 | 08:33 AM
SkaiWu's Avatar
i tried eyeing it the screws from the itr won't match the ones i circled in black, they are too far apart
any others chim in?
ill check autozone for battery soon, it died
Modified by SkaiWu at 9:41 AM 5/31/2008
Old May 31, 2008 | 11:47 AM
Dogginator's Avatar
Daisy... Daisy...
Regarding the battery, just buy one and swap it. It takes about 15 minutes total.
For the spoiler, the stock bolt spacing is just about 1 7/8". The red ones seem to be correct. The outer ones that penetrate the sealant are mystery holes.
Old May 31, 2008 | 12:30 PM
SkaiWu's Avatar
^ yes a straight answer, thanks ill have those drilled out and the mystery holes were actually made for the 3 piece
it worked i drilled the red holes and got it fitting well
Modified by SkaiWu at 7:03 PM 5/31/2008
White_crex
Oct 6, 2014 10:14 AM
coup3y
Apr 6, 2009 06:12 PM
ben_eg6
Oct 5, 2004 04:04 PM
HondaRcB
Mar 4, 2003 03:01 AM
stevecockrill
Jan 9, 2002 03:38 AM
