New Product!! Xenonworx D2S HID BI-Xenon Projector
Old May 30, 2008 | 07:09 PM
DrivenMC's Avatar
Banned
Default New Product!! Xenonworx D2S HID BI-Xenon Projector
This is a New Product that we are Developing. This kit is designed to fit into your existing Reflector housing. Let me know what you think.
Patent Product, Rights Reserved
TUV Approved
TS16949
ISO9001
Old May 30, 2008 | 07:11 PM
DrivenMC's Avatar
Banned
Default Re: New Product!! Xenonworx D2S HID BI-Xenon Projector (DrivenMC)
Low Beam
High Beam
Old May 31, 2008 | 02:03 PM
bpr0422's Avatar
You still need to take apart the headlight...
what makes it different from a retro?
Old Jun 1, 2008 | 01:58 AM
chickenwing's Avatar
Default Re: New Product!! Xenonworx D2S HID BI-Xenon Projector (bpr0422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">You still need to take apart the headlight...
what makes it different from a retro?</TD></TR></TABLE>
i think this is a retro fit conversion kit.
Old Jun 1, 2008 | 06:54 AM
DrivenMC's Avatar
Banned
Default Re: New Product!! Xenonworx D2S HID BI-Xenon Projector (chickenwing)
This is a retro fit conversion, Unlike usually retro's the projector slides through your existing hole cut out for your Halogen Bulb. Then attaches by a retaining nut in the back.
Old Jun 1, 2008 | 09:58 AM
bpr0422's Avatar
ooo... looked like a clamping system...
so the big question is price...
is it worth getting your kit, over using oem components?
Old Jun 1, 2008 | 11:09 AM
DrivenMC's Avatar
Banned
We are still developing the Projectors. I need some input from everyone, Let me know what you all think.
Pricing has not yet been determined, It is going to be very competitively priced.
Old Jun 1, 2008 | 01:00 PM
bpr0422's Avatar
cutoff could be more colorful...
sortof like the tsx color mod...
also how wide is the beam???
cause it looks like there is a slight hotspot at the center...
Old Jun 1, 2008 | 02:49 PM
DrivenMC's Avatar
Banned
Here is a longer view point.
Old Jun 1, 2008 | 08:32 PM
bpr0422's Avatar
does it have to come with the halo ring?
also is the halo ring led or ccfl?
Old Jun 1, 2008 | 10:45 PM
chawski's Avatar
so what is the upside to this over oe? just that you can use a conversion kit bulb in it?
Old Jun 2, 2008 | 02:18 AM
Default Re: (chawski)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chawski &raquo;</TD></TR><TR><TD CLASS="quote">so what is the upside to this over oe? just that you can use a conversion kit bulb in it?</TD></TR></TABLE>
i think the upside it is a projector that can do both hi and low beam in one unit.
if you notice that all cars that come equipped with hid have a separate lamp for high beams.
Old Jun 2, 2008 | 04:25 AM
DrivenMC's Avatar
Banned
It can be taken off, CCFL
Old Jun 2, 2008 | 04:43 AM
DrivenMC's Avatar
Banned
Some new vehicle's come with BI-Xenon projectors, The OEM Version is difficult to install as a Conversion. We Are simplifying the system, So that more people can perform Conversions. The projector houses a D-Series bulb, Overall You can purchase all the parts needed from Xenonworx. Ballasts, Bulbs, Projectors, controllers and wiring harnesses.
I will post pictures with the internal components.
Modified by DrivenMC at 5:55 AM 6/2/2008
Old Jun 2, 2008 | 05:08 AM
devani's Avatar
Default Re: (DrivenMC)
if you can do a A/B comparison between well known projectors, it's going to sell alot faster....it looks like you mount this from inside and put a nut on the outside...
Old Jun 2, 2008 | 05:22 AM
DrivenMC's Avatar
Banned
Default Re: (devani)
Great Idea, I will work on a comparative analysis once the product is finished. Very correct on the mounting.
Old Jun 3, 2008 | 12:09 AM
bmoua's Avatar
if the price is right and fitment is good, i'd def consider picking this up.
Old Jun 3, 2008 | 06:31 AM
denshu's Avatar
Default Re: (bmoua)
I think you need a better picture of the light spread in a darker place.
To me the beam seems a bit dim and i can really notice the hotspot in the middle.
But if price is right, anythign is better then plug and play.
You should compare these to E46 single xenon or Tsx since those are the best bang for the buck OEM projectors.
Old Jun 3, 2008 | 08:58 AM
DrivenMC's Avatar
Banned
Default Re: (denshu)
Will Do. Thanks for the input.
Old Jun 3, 2008 | 09:53 AM
DEIVIONCRX's Avatar
Any pics of this installed in the headlight. This is a great idea and depending on price might be interested in some.
Old Jun 3, 2008 | 01:11 PM
Markb16a's Avatar
Default Re:
I would liketo see these in some headlights as well.
Old Jun 3, 2008 | 03:51 PM
chawski's Avatar
so how do these mount? from the looks of it you would need to fab a bracket for them?
Old Jun 3, 2008 | 04:15 PM
DrivenMC's Avatar
Banned
I just left Mooresville This Morning, Anyways you Mount the Projector by a Retaining Nut on the Base. No Brackets Needed
Old Jun 3, 2008 | 05:59 PM
Importn2oRacer's Avatar
Estimated price please
Old Jun 3, 2008 | 11:40 PM
bmoua's Avatar
Default Re: (Importn2oRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Importn2oRacer &raquo;</TD></TR><TR><TD CLASS="quote">Estimated price please</TD></TR></TABLE>
