Civic Si disc conversion
Old Jul 16, 2002 | 08:31 AM
WalkEX99's Avatar
Default Civic Si disc conversion
There was just a topic similar to this the other day but I wasn't sure if I understood what I was reading. They were saying that the conversion for OEM disc brakes from a 6th gen Si onto an 6th gen EX only costs $400. What's the deal here? Is it really that cheap?!
Old Jul 16, 2002 | 08:33 AM
JDM_SiR_II_EG's Avatar
Default Re: Civic Si disc conversion (WalkEX99)
you can use the trailing arms from a 5th gen civic si/del sol vtec with the stock lower control arms....i dunno about the front though...but since u can use the 5th parts...they r pretty common and cheap.
Old Jul 16, 2002 | 09:01 AM
RokketRide's Avatar
If you are talking about front brakes, 6th gen EX and Si are the same.
If you are talking about rear, like JDM says, the parts are common. I got mine from a 94 Integra
[Modified by RokketRide, 10:03 AM 7/16/2002]
Old Jul 16, 2002 | 09:52 AM
B96v6's Avatar
Default Re: Civic Si disc conversion (RokketRide)
Can you use Integra parts on a 6th gen? I'd like to get rear discs for my hatch, but was under the impression that I could only use SI discs. If I can use Integra parts, will that affect the rear suspension (ie. shock mounting points, swaybar links)? Thanks for the info...
B96v6
Old Jul 16, 2002 | 11:18 AM
ruthless013's Avatar
Default Re: Civic Si disc conversion (B96v6)
Si parts will swap over perfect, just make sure you get the parking brake cables, t/a, etc. you shouldn't spend more than $350 for those, and at that price they may or may not come with pads and rotors. you'll probably want new pads/rotors and stainless lines, fluid, which will run you another $200 +/-. the swap itself is pretty straight forward with the right tools.
if you go with integra parts, you'll hae to mix match t/a, parking brake cable. talk to someone who's done the exact swap (into 6thgen hatch) if you're gonna use anything other than si parts.
it's been said before, but for the money you're about to spend, you could get a big brake upgrade in the front and probably get better overall stopping power (especially if you have 16inch+ rims). i just hated the way drums look, plus you can't buy 'high performance drums' i don't think.
good luck.
Old Jul 16, 2002 | 12:35 PM
CheezeFrog's Avatar
Default Re: Civic Si disc conversion (ruthless013)
I got my rear discs off a '94 Integra. The parking brake cables appeared to be too short at first, but there's enough adjustability in the stock EK handbrake "load leveler" thing to take up the slack. Beyond that, it's a bolt-up affair.
Old Jul 16, 2002 | 01:09 PM
WalkEX99's Avatar
Default Re: Civic Si disc conversion (CheezeFrog)
Sooo $400-$500 is about how much to expect to spend?
(I'm a poor college kid with an extremely tight budget)
Old Jul 17, 2002 | 09:20 PM
CheezeFrog's Avatar
That's way too much. I wouldn't pay over $250 for a set of rear discs. And that's including the entire trailing arm assemblies & LCA's.
Old Jul 18, 2002 | 12:44 AM
madhatch's Avatar
is that local? The calipers alnone are 100 bucks a piece. You must have some good yards there. You should look into putting a package together and selling it. I wouls give you 300 if you could get the LCAs Calipers Rotors and E brake cables.
Old Jul 18, 2002 | 02:53 AM
D16Z6racing's Avatar
Default Re: Civic Si disc conversion (madhatch)
Not quite sure if this is what your looking for, but I just came across it.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1844127379
Old Jul 18, 2002 | 04:50 AM
EKB18BPR3's Avatar
Default Re: Civic Si disc conversion (buster13)
u should just carve a hole on ur floor and use ur feet to stop, like the flinstones!
Old Jul 18, 2002 | 06:01 AM
WalkEX99's Avatar
QUOTE]Not quite sure if this is what your looking for, but I just came across it.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1844127379[/QUOTE]
Will the 92-95 conversion bolt up to a 6th gen?
beyond-redline
Mar 14, 2021 04:06 PM
colinfindlay
Dec 4, 2012 05:11 PM
emoney803
Oct 23, 2012 11:03 AM
Heinvenkin2
May 20, 2002 11:15 AM
heinvenkin
Nov 1, 2001 02:35 PM
