Bypassing
Old May 30, 2008 | 05:13 PM
8_6 luder's Avatar
Default Bypassing
Just wondering if anyone knows what this piece is , its function , and if it can be bypassed to further cool the intake charge . Got a hondata heat shield on the way did the throttle body bypass mod and I was looking for any other bypassing that might have a positive affect on intake temp . This part sits directly in front of the intake mani. It has two coolant hoses that circulate through it to the thermostat housing .
Old May 30, 2008 | 06:43 PM
H22Luda720's Avatar
Default Re: Bypassing (8_6 luder)
Idle Air Control valve, Keep it
Edit: You can lose the coolant lines though, They keep it from freezing and sticking in the cold. Considering your in Ga, I dont think you need them, Imo
Old May 30, 2008 | 09:34 PM
shadow29485's Avatar
Default Re: Bypassing (H22Luda720)
"Idle Air Control valve, Keep it."
______________________________
I don't think that it will benifit you at all to block it off, or by-pass it.
Take it off and clean the screen in it, if your having idle issues after that, I'm thinking it's a little more digging into you emmisions, or vacuums pertaing too.
Not sure though.
Old May 31, 2008 | 09:36 AM
8_6 luder's Avatar
Default Re: Bypassing (shadow29485)
so I can do without the lines , huh
Old May 31, 2008 | 04:26 PM
Apex1972's Avatar
Yeah I removed my lines about 2.5 years ago. No problems at all. How far is Kingsland from Macon. We have a few 4th genners here, maybe we could set up a meet sometime.
Old May 31, 2008 | 05:23 PM
8_6 luder's Avatar
Default Re: Bypassing (Apex1972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex1972 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I removed my lines about 2.5 years ago. No problems at all. How far is Kingsland from Macon. We have a few 4th genners here, maybe we could set up a meet sometime.</TD></TR></TABLE>
did you plug the openings ? umm macons about a 3 hour drive from here . Im on the flordia line so theirs a huge import tuner scene right near me in jacksonville , but a lude meet is always a cool idea . Another thing did you notice any difference after the removal? I noticed a little more pull after the tb bypass . cant wait to get my heatshield.
Old Jun 1, 2008 | 04:02 PM
Apex1972's Avatar
No the hose is attached to a plate that screws onto the bottom of the IACV. I will let you know when I am in the Jacksonville area.
Old Jun 1, 2008 | 07:23 PM
8_6 luder's Avatar
koo . I just pulled one line off , shortened the other and redirected it back to the thermo housing . I've got my auto meter water temp sender teed in between it . Still getting a good temp reading and all seems fine for now (knocks on wood 3 times) .
kev92ex4door
Jul 31, 2008 12:27 PM
royalfelix
Dec 10, 2007 11:43 AM
EKHWhat
Feb 19, 2007 05:24 PM
B18C_EJ8
Apr 20, 2006 04:14 AM
huge230
Mar 29, 2006 05:19 PM
