CEL -searched, this is new
Old May 30, 2008 | 12:40 PM
checkenginelight2's Avatar
Default CEL -searched, this is new
A little help please. I got the 4 CEL's that commonly pop up on 96-98 honda civics. I drive a stock ex d16y8 with i/h/e. These 4 CEL's are prim and second o2 sensors, speed sensor, and electrical load detector. Read some stuff on here and people were getting the same codes, except their fuses (alternator) were blowing out and their cars dying. I have no blown fuses, no sign of wear on the wires in back of my throttle body, switched all speedsensor, underhood fuse box, o2s. CEL still there, tried erasing it with code reader-still there. What could it be? Has anyone experienced this? By the way, the CEL poped up a month ago and I'm still driving my car fine. The only thing is that the speedometer goes crazy. Thanks for any help.
Old May 30, 2008 | 12:45 PM
iluvmy2000civicex's Avatar
Default Re: CEL -searched, this is new (checkenginelight2)
I know you said you erased them with a code reader but did you also reset the ECU? Dont know if itd make any difference or not. Just trying to help.
Old May 31, 2008 | 04:10 AM
Default Re: CEL -searched, this is new (iluvmy2000civicex)
How would I reset the ECU other than pulling the neg. off the battery? Would I pull the harness off the ECU? Thanks, any suggestions help at this point.
Old May 31, 2008 | 04:20 AM
NHswaps13203's Avatar
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
either way will work
Old May 31, 2008 | 04:25 AM
Default Re: CEL -searched, this is new (NHswaps13203)
I've already pulled the neg. off a couple of times. What I haven't done is pull the harness off the ECU. Would it matter?
Old May 31, 2008 | 04:39 AM
Former User's Avatar
Easiest method -- Pull the 7.5A BACKUP fuse for a couple of minutes and then reinsert.
Old May 31, 2008 | 04:55 AM
Default Re: CEL -searched, this is new (RonJ@HT)
done all of that. cel is still on? any suggestions on what's causing it? short anywhere that I haven't thought of? Any other experiences?
Old May 31, 2008 | 05:15 AM
Sure sounds like the common short circuit problem that affects the fuse 15 circuit:
http://autorepair.about.com/li...d.htm
Have you checked for other possible blown fuses?
Have you inspected other areas of the wire harness for damage?
DZO
11
May 16, 2012 10:49 PM
sPcIaLkSeRiEs
Sep 14, 2009 06:32 AM
Si_Guy2000
Sep 4, 2009 11:05 AM
elips0id
Apr 16, 2005 08:30 AM
genetsang
Jun 24, 2003 12:24 PM
