94 GSR wont start after new intake manifold?
Old May 30, 2008 | 12:15 PM
94Doc.VTECH's Avatar
Default 94 GSR wont start after new intake manifold?
I have a 94 GSR well maintained. I recently got a skunk2 intake manifold from a friend after putting it on i had a little trouble with some vacuum lines and then i got it started it. it was idling high around 1500-2k. so i turned it off and made sure everything was okay. i unpluged the IAC and started it up for about 20 seconds and then the car died on me. It hasnt started up since. The plugs only have about 30k on them, and same with the wires. I went down and got a new ignition coil and still nothing. The car cranks hard, so the battery should be fine. But it wont start up. The cap and rotor also are newer and good condition. Any ideas what it could be? Oh yeah and im getting fuel to the motor... so idk
Old May 30, 2008 | 12:47 PM
bigkvn77's Avatar
Default Re: 94 GSR wont start after new intake manifold? (94Doc.VTECH)
when you unplugged the iac did the high idle fix it self. Chances are you have a vacuum leak somewhere.
Old May 30, 2008 | 01:18 PM
kraig8's Avatar
make sure you didnt swap the throttle body and map sensor plugs. its a common mistake. there the same plugs
Old May 30, 2008 | 03:28 PM
Default Re: 94 GSR wont start after new intake manifold? (bigkvn77)
yeah it went back down to around 750 and was fine...
but now the car wont start at all? any ideas?
Old May 30, 2008 | 03:29 PM
I dont think i did but if i did swap sensors would the car not start up after?
and how can you tell the difference between the two?
thanks
br8crumb
Mar 27, 2014 09:13 PM
beatontheeznutz
Aug 11, 2012 05:08 PM
Bulldogg83
Oct 19, 2003 05:50 PM
Bulldogg83
Oct 19, 2003 05:49 PM
Bulldogg83
Oct 18, 2003 12:18 PM
