Dizzy at full advance to hit base timing.
Old May 30, 2008 | 09:12 AM
ho bag's Avatar
Default Dizzy at full advance to hit base timing.
So i was having issues with a code 9 on my car and i swapped the dizzy (no change) and the ecu (fixed it).....
However now when i set base timing i have to turn the dizzy full advance just to get the base timing to the center mark. This is on a d16y8.
The idle is set to 750 and rad fan had kicked on 3 times before setting the idle.
Old May 30, 2008 | 09:25 AM
wmac's Avatar
if your d16y8 is stock (stock cam, stock cam gear) then probably your timing belt is off by a tooth or you have the wrong distributor
Old May 30, 2008 | 09:34 AM
ho bag's Avatar
Default Re: (wmac)
Belt is not off by a tooth, The dizzy i took off lined up fine but threw a code 9. The dizzy i put on lined up as well btu still threw a code 9.
Once i changed the ecu to another one from a 97 el (d16y8 as well) it needed to be at full advance to hit the base timing.
ArtyTheKid
Dec 25, 2012 10:15 AM
Tchleung
Mar 5, 2005 06:58 AM
ATS*Mark
Sep 12, 2004 05:03 PM
Vtec92Civic
Apr 8, 2004 09:57 PM
