EM1 Clutser in GSR?
from what i've seen the si cluster is around 3x more expensive than one from a gsr. considering that it takes modification to both mount and wire up an integra cluster into a civic i'd say its safe to assume that the oppositte is true as well. the integra cluster doesn't fit very well into a civic dash, leaving nasty looking gaps all around, so you'll probably get the same thing when putting a civic cluster into an integra.
