LS motor(b4 lsvtec), vtec water pump and vtec timing belt
im going to swap in a LS swap soon and going to change out the water pump and timing belt. i was plannin on using itr/gsr water pump and itr/gsr timing belt on the stock ls motor. then BAR i, then go LSVTEC.
my question is, can i use the itr/gsr parts on the LS stock motor?
OR do i have to use a LS water pump and LS timing when its a stock LS motor?
HELP ASAP, buying parts tomorrrow
275Performance
Jan 4, 2003 04:45 PM
