Good way to remove engine ????
what's a good way to remove the engine and install another. I dont have a hoist right now and so i need to remove it asap.. Some help here..
The only option without a hoist is out the bottom.
Support the motor-
Unhook all plugs, etc....-
Raise car off of motor and pull it out-
Install in reverse
There are quite a few threads about this if you search it.
Support the motor-
Install in reverse
did it 2 weeks ago...wicked easy.
i even installed it by myself which i thought was an accomplishment.
https://honda-tech.com/zerothread?id=2283567
You have any pictures ?????? you think u could put the car on ramps and then just lowering the motor with jacks ??
get everything undone leave the tranny mount and block mount connected then drop it all the way down onto a cart take the mounts off raise it back up till the engine clears
But um bad thing is i dont have the tranny mount. i now get whats you guys are saying. So just unplug everything connected to the motor and then just leave a mount and then lower the car so that motor could sit on the floor right...
NA JDM GSR
Nov 29, 2006 08:28 PM
b16ek4
Jun 25, 2005 10:35 AM
Loveless
Jan 4, 2004 04:25 PM
