LS/vtec 84mm setup.....what cams to use
Old May 29, 2008 | 07:55 PM
sc34dx's Avatar
Default LS/vtec 84mm setup.....what cams to use
hay everyone i am leaving the turbo scene and trying my luck with all motor...i have a 98 ek coupe...and i am working on a ls/vtec.....my goal is to make around 230-240whp...i dont know if my goal is reachable but from the reasearch i have done i have found that it can be done....with proper tuning...the one thing that i dont know on what to get is CAMS...i have a budget and i dont want to spend more than $500 first i will start with my setup and then a list of cams i am interested in....
Golden eagle 84mm LS bottom end
12.5:1 comp Manley pistons
Golden eagle H-Beams
b16 head no porting done
ferrea Std size valves
skunk 2 springs
skunk 2 retainers
pte 440cc injectors
aeromotive fuel regulator
walbro 255
JG intake manifold
70mm rpm services throthle body
Hytec replica header
3" exhaust
so now i was intersted in the following cams
Blox compition HSL
Blox compition Type C
Toda Type B
i can get any of the three for $400 bucks...all new exept for the Todas....
so which cam will help me make the power i want...or will none of those do it for me....????
any imput would be nice..thanks to everyone
Old May 30, 2008 | 10:58 AM
sc34dx's Avatar
bump guys no one has any advise????
Old May 30, 2008 | 12:54 PM
b18avtec(A!!M0TOR)'s Avatar
Default Re: (sc34dx)
i've seen good power from all those cams. hsl or the c might be best for ur set up. good luck. hope it helps.
Old May 30, 2008 | 01:00 PM
b20vtech's Avatar
Default Re: LS/vtec 84mm setup.....what cams to use (sc34dx)
any of those cams will do!! i have seen many of those in a 2.0 motors breaking 230+ whp!!
Old May 30, 2008 | 07:48 PM
sc34dx's Avatar
thanks everyone...i will let you know what i decide to get....anymore help would be nice
Old May 31, 2008 | 03:33 PM
AMLS4dr200whp's Avatar
I kno the hsl make good power one guy on here on his 82mm gsr made 229 on them so I think you should be fine
Old May 31, 2008 | 09:26 PM
sc34dx's Avatar
yea im leaning more towards the blox type c because they are very similar to the jun III's and those make great power and have good mid range
crcale
30
Jul 11, 2011 05:17 PM
Ls_eg6
Mar 6, 2009 06:32 PM
playa-ej1
19
Jul 23, 2007 11:08 PM
keebler65
Feb 6, 2004 02:26 PM
VTEC-DA
Jan 2, 2003 07:24 PM
