GSR Tranny with B20B with Intermediate shaft? In 94 Civic CX HB
Old Jul 16, 2002 | 05:54 AM
crxman00's Avatar
Default GSR Tranny with B20B with Intermediate shaft? In 94 Civic CX HB
Which Intermediate shaft do I use? and will one come on the motor?
THanks
Old Jul 16, 2002 | 07:38 AM
Newman's Avatar
New User
Default Re: GSR Tranny with B20B with Intermediate shaft? In 94 Civic CX HB (crxman00)
Any B-series intermediate shaft... all the same size.
FYI, on my turbo B20 setup (also GSR tranny), all I had laying around was an intermediate shaft and axles from a 90-93 Integra... they all work the same (B-series that is).
Old Jul 16, 2002 | 09:32 AM
g's integ's Avatar
Default Re: GSR Tranny with B20B with Intermediate shaft? In 94 Civic CX HB (Newman)
Any 90 and up Teg axles will do fine.
Old Jul 16, 2002 | 10:05 AM
BROOD's Avatar
Default Re: GSR Tranny with B20B with Intermediate shaft? In 94 Civic CX HB (g's hybrid)
What they said (above)
I'm using a 94 Teg LS int. shaft with my GSR trans
Old Jul 16, 2002 | 11:36 AM
blufke's Avatar
Default Re: GSR Tranny with B20B with Intermediate shaft? In 94 Civic CX HB (SLPR)
what is the int. shaft? is it inside the tranny, i asked this before but what the crapola is it? im getting my swap soon, how do i make sure im getting it.
Old Jul 16, 2002 | 11:51 AM
g's integ's Avatar
Default Re: GSR Tranny with B20B with Intermediate shaft? In 94 Civic CX HB (blufke)
It's on the block and located right next to the oil pan.
Old Jul 16, 2002 | 11:53 AM
blufke's Avatar
its on the block??
Old Jul 16, 2002 | 11:56 AM
g's integ's Avatar
Yes
Old Jul 16, 2002 | 12:14 PM
BROOD's Avatar
Here let me assist
That is an intermeadiate shaft with a inner CV from an axel still attached to it.
[Modified by SLPR, 1:42 PM 7/16/2002]
Old Jul 16, 2002 | 12:19 PM
crxman00's Avatar
Thanks
Old Jul 21, 2002 | 08:26 PM
bikeboy80's Avatar
speaking of int shafts, does anyone know of a trick to seperate the drive shaft from it? i could not separate it last time my motor came out so i just removed the as one piece but this time it has to because the drive shaft is damaged, anyone have any ideas, thanks
Old Jul 23, 2002 | 04:37 AM
kinesistech's Avatar
Default Re: GSR Tranny with B20B with Intermediate shaft? In 94 Civic CX HB (bikeboy80)
I simply aim my air hammer at the cv joint for the axle and squeeze. I was able to loosen them with a rubber mallet pounding it on everyside while turning it over and over until it came loose.
Old Jul 23, 2002 | 06:09 PM
AmauryR's Avatar
Default Re: GSR Tranny with B20B with Intermediate shaft? In 94 Civic CX HB (kinesistech)
also needed to mention -
'90-93 integra (b-series) int-shaft is male-female
-or the '90-93 axles are male on both ends (both side)
'94+integra (and del sol/civic si?) int-shaft is male-male
- the '94+ integra axles are male-male on the pass. side, and male/female
on the driver(intermediate) side...
when you run a '90-93 intermediate shaft, run axles from that year
when you do the '94+ run '94+ axles (I found that out the hard-way).
-l8r
RunninEg6
Feb 15, 2009 09:38 PM
GI8U2racing
Aug 29, 2007 06:26 PM
lance_ecl
10
Jul 2, 2007 07:58 PM
shiftgear8000
May 27, 2004 07:22 AM
Black R
Sep 10, 2003 04:38 PM
