h22a4 Timing Help!
Old May 29, 2008 | 04:06 PM
7hugl3oy's Avatar
Default h22a4 Timing Help!
hmm posted on another post havin alot of problemz wit motor..wanted to kno details on everything i need to timing oil pump? cams?(aem gears) crank? water pump...where marks are located?...would this cause oil leakz? bogging? no power? dieing out? poppin out of the exhaust? smokin?...please help need fixed asap. please
Old May 29, 2008 | 07:44 PM
gstrudler's Avatar
Default Re: h22a4 Timing Help! (7hugl3oy)
Did you do the modifications to the motor? Have you played with the timing at all? To check timing for everything, buy a Helm's for the 97-01 Prelude and it will walk you through step by step how to make sure everything is set to TDC (crank, cams, balance shafts). I would first make sure your adjustable cam gears are set to 0, 0. Do you have any kind of engine management (Hondata, etc)? Your oil leaks are likely from bad seals, not timing. Hard to say about the other things.
revhardEK
Apr 5, 2012 09:03 AM
kazaa1872
Jan 26, 2009 11:38 AM
NatedoggAZ
14
Apr 13, 2005 09:51 AM
