Pcv Valve adapter plz help
Old May 29, 2008 | 11:53 AM
lotofIntegraty's Avatar
Default Pcv Valve adapter plz help
okay i was trying to trim the hose that was connected in between the pcv valve and the pcv valve adapter(sum wud consider it the black box underneath the intake manifold).. well anywai i couldnt take out the clips on the bottom so my brother was trying to yank it out by pulling n twisting it.. he took off the hose alright but he broke off the tip where the hose goes to.. so now i cant put the hose back on to that black box coz it wouldnt hold on to anything.. wat do i do? is it still fixable?
Old May 29, 2008 | 11:59 AM
dplatt's Avatar
Default Re: Pcv Valve adapter plz help (lotofIntegraty)
Sounds like you need a new PCV-tube.
4 11855-PR3-000 TUBE A, PCV 1
Or possibly
3 11854-PR3-000 JOINT, BREATHER CHAMBER
Old May 29, 2008 | 12:13 PM
Default Re: Pcv Valve adapter plz help (dplatt)
i think i need number 3 or 2... one of em thats connected to that box... where do i buy that? and how much is it... and can i do dat myself?
Old May 29, 2008 | 12:19 PM
dplatt's Avatar
What year and trim level is your car? Call your local Acura dealership. It's about $5.
Old May 29, 2008 | 12:45 PM
a 94 ls... wat as tha part called? numba 2?
Old May 29, 2008 | 01:33 PM
dplatt's Avatar
2 11853-PR3-000 GROMMET, BREATHER CHAMBER 1994 INTEGRA $2.53
Old May 30, 2008 | 01:30 PM
oh thank you!! dont mean to be a pain in da butt but what about 13... ima go buy it soon.. i havent bin using my teg lately..
Old Nov 2, 2009 | 01:07 AM
jeffyjeff's Avatar
i guess dan's answer is correct. thanks for the diagram. where is the pcv valve grommet. much thanks!
Old Apr 10, 2010 | 09:47 AM
YodajdmEK4's Avatar
Here you go.
Top piece is PCV valve. Lower piece is lower hose.
Old Apr 11, 2010 | 06:58 AM
mark pones's Avatar
wheres this located on a gsr? for some reason i cant remember..
crxt25turbo
Mar 28, 2024 12:07 PM
drew_kousk
Jul 26, 2008 09:21 AM
foreverwefall
Oct 25, 2006 08:36 AM
civicguy1984
Nov 11, 2004 10:40 AM
Boost2NA
Apr 1, 2004 12:56 PM
