pcv valve
Old Oct 24, 2006 | 07:32 PM
foreverwefall's Avatar
Default pcv valve
ok i have a ls engine i need to know if i have to run the pcv valve to the black box?? if so where do i get the hose to connect it since it needs a specfic hose??
Old Oct 24, 2006 | 07:35 PM
DC2 Mang's Avatar
Default Re: pcv valve (foreverwefall)
you can run 3/8 in tubing from the intake manifold to the valve that is in the black box
if you want it to be like it came from the factory then you have to go to the honda or acura dealership and purchase the gromit that rests in the hole in the intake manifold and holds the pcv valve
Old Oct 25, 2006 | 08:36 AM
Sam92Teg's Avatar
Default Re: pcv valve (DC2 Mang)
On my 92 RS, there is also a plastic fitting that goes into the bottom of the hose that fits into the black box.
crxt25turbo
Mar 28, 2024 12:07 PM
lotofIntegraty
Apr 11, 2010 06:58 AM
K i l l a B e e.
Mar 4, 2009 10:31 AM
drew_kousk
Jul 26, 2008 09:21 AM
yostuhfoo
May 16, 2007 09:43 AM
