no resister box obd1
ok we are converting dpfi to mpfi and to obd1 i was told that since we have high pulse injectors aka obd1 injectors we dont need a resister box.If thats true how do you wire up the injectors? I have done research and found nothing need this running asap!!
well i have had the same thread going if you use the oem stock inj you need the frb but if you are using aftermarkeft ones i would buy the saturated inj they do not need the frb the peak and hold inj do to eliminate frb disconnect it the cut the male plug off and then solder all 5 wires
surkitroller
Dec 29, 2009 12:58 PM
lilsicsoul
Jan 22, 2009 09:31 PM
