manual trans with auto ecu?
got a 96 civic dx automatic that i got for cheap, tranny is toasted, im going to put a 93 si manual trans on it, got everything for the swap but no ecu, will the auto ecu in the car be ok or do i need to swap for a manual one absolutely? trying to keep cost as low as possible on this car thanks! i think it will work but will get a check engine light and i think the rev limiter is lower on the auto tranny?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedr »</TD></TR><TR><TD CLASS="quote">got a 96 civic dx automatic that i got for cheap, tranny is toasted, im going to put a 93 si manual trans on it, got everything for the swap but no ecu, will the auto ecu in the car be ok or do i need to swap for a manual one absolutely? trying to keep cost as low as possible on this car thanks! i think it will work but will get a check engine light and i think the rev limiter is lower on the auto tranny?</TD></TR></TABLE>
it'll work, you'll just have a cel for the trans lock up soleniod that you will no longer have (AT part)
ferio-ichi3
27
Apr 16, 2013 12:48 PM
ef8b16a1
May 23, 2005 02:19 PM
