gsr problem
Old May 29, 2008 | 08:39 AM
standbackimapro's Avatar
Default gsr problem
i have A Gsr in my integra, i have an a/f gauge hooked up and its running on the rich side, its also running fairly bad, kinda sounds like a boxer motor, we did a compression test, all the cylinders are at about 200, is that normal?
The first plug ( closest to the distributor) that i took out, had alot of oil on it the rest were dry but had alot of carbon build up, im assuming from running rich.
what can i check to see whats going on
Old Jun 3, 2008 | 01:44 PM
vtecb18c's Avatar
Default Re: gsr problem (standbackimapro)
are you burning oil?it could be running 3 cylinders
blackeg
Jul 27, 2009 04:15 AM
94eh2
Oct 27, 2007 10:30 AM
5genprelude
Mar 24, 2006 09:22 AM
