Wheel spacer Question
Hey Guys.
I just purchased a new set of wheels and need to run 10 mm spacers. My question is what are the pro's and con's of getting hubcentric spacers versus non-hubcentric spacers? Will there be alot of vibration if I opt not to get hubcentric? Are there any brands that are better than others as in quality and effectiveness? Are there any issues I should tackle or things I should know before buying spacers? Sorry to sound like a tool but the more reserach I did the more confused I got so I thought I would ask you guys.
Thanks,
Thanks,
Re: Wheel spacer Question (SuShiBoiiii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuShiBoiiii »</TD></TR><TR><TD CLASS="quote">i wouldnt go more then 7 mm on stock studs </TD></TR></TABLE>
You shouldnt go even more then 5mm on a stock stud. 5mm is already pushing it. You need at least 6-8 full turns of the lug nut to be safely driving. If you plan on getting 10mm spacer, make sure its HUB CENTRIC! Dont buy the cheap ebay ****, or you'll get owned by vibrations, or the spacer possibly cracking at high temps. and stress. I recommend going with project kics or H&R. I run a 9mm custom hub centric spacer with arp extended studs.
Re: Wheel spacer Question (.:Made in OC:.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .:Made in OC:. »</TD></TR><TR><TD CLASS="quote">
You shouldnt go even more then 5mm on a stock stud. 5mm is already pushing it. You need at least 6-8 full turns of the lug nut to be safely driving. If you plan on getting 10mm spacer, make sure its HUB CENTRIC! Dont buy the cheap ebay ****, or you'll get owned by vibrations, or the spacer possibly cracking at high temps. and stress. I recommend going with project kics or H&R. I run a 9mm custom hub centric spacer with arp extended studs. </TD></TR></TABLE>
he is right... i have personally done 7mm to 10mm on stock length studs but only for fitment purposes but felt very uneasy about it and soon removed them. either use hubcentric spacers w/extended lugs or just ditch those wheels and get ones w/ proper hub cleanace and or fitment for your application.
Re: (starbai)
do they even make 6.5 lol you might as well go 7mm i mean if its for dd you'll be fine but anything after that make sure you get some extended studs
they've got 6.5 on ebay
but the more I read the more I dont wnana go with e-bay ones.
I'm thinking some Hub Centric H&Rs would be safer, and I'll willingly spend the extra money to do that.
anyone know of a good website that can sell me the spacers and some extended wheel studs in a package deal?
Re: (starbai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by starbai »</TD></TR><TR><TD CLASS="quote">they've got 6.5 on ebay
anyone know of a good website that can sell me the spacers and some extended wheel studs in a package deal? </TD></TR></TABLE>
i think its just like air intake aem vs ebay. lol
mikeunreal2
04-16-2006 02:55 AM
